Turning Signal Issue
Old May 30, 2014
onedr's Avatar
onedr is an unknown quantity at this point
Okay, so I don't know if it's just me brainfarting n this is normal, but once in a while I'll hit a bump hard enough that for some reason, when i signal right, my front right bulb won't work, and the signal will flash rapidly as if the bulb is burnt out. But at the same time when my hazard's are on, the right bulb will work normally, just not when signalling... then i'll hit a hard bump again, and it'll go back to normal.
Just last week i fixed my DRL issue by soldering those points in the circuit board in the DRL module and was wondering if the issue could be there again, or maybe I need to be looking somewhere else?
Old May 30, 2014
CraigW's Avatar
Re: Turning Signal Issue
Sounds like intermittent connection.
I would start at problem bulb, and work back.
Reseat or replace bulb, reseat connector at socket.
steveneddy
May 19, 2015 02:39 PM
shaejb15
Apr 26, 2015 07:44 PM
Fastfebur
Apr 22, 2015 01:37 PM
wawacito
May 14, 2002 07:33 PM
blackbullet
Dec 1, 2001 03:44 PM
