engine tick cause?
Old May 30, 2014
jess21's Avatar
jess21 is an unknown quantity at this point
Thumbs down engine tick cause?
I have a 2001 civic coupe. Manual trans. It has 141k on it. About 6 months ago it has started ticking under load. Mostly on cold start and here and there if I need to speed up afterslowing way down. I just had the valves adjusted yesterday and it has made zero difference. Im hoping its not a rod knock. Any suggestions would be appreciated!!!! Thanks.
Old May 30, 2014
mikey1's Avatar
Re: engine tick cause?
sometimes ticking under load/acceleration can be cause by an exhaust leak close to the engine, i would remove the heat shield from the manifold and check for a leak around the header/cat area, also look for cracks in the header
Old May 30, 2014
Exhaust leaks: cracked manifold, broken studs, etc.
OPGForce
Exterior DIY
125
May 20, 2019 04:11 PM
Supramk3
May 11, 2015 07:55 PM
BootyDo
May 7, 2015 04:46 PM
Cross
Jan 6, 2002 01:31 AM
Grey
Nov 9, 2001 09:41 PM
