Brake Lights 2004 Civic
Old Dec 31, 2015
Cheddar's Avatar
Cheddar is an unknown quantity at this point
Driver side brake light was out. Switched the bulbs between right and left now both don't work. The third central brake light is still active and works fine. Replaced bulbs for both right and left and they still don't work. Hazard lights come on, horn works and I checked the fuse anyways it isn't blown. I'm stumped since the Hazards and the horn works and the third brake light works. Any advice?
Old Jan 1, 2016
mac25's Avatar
Dr Krieger of Modification
Re: Brake Lights 2004 Civic
Buy a Haynes manual
-look through the electrical diagram and test the fuses and relays
as well as the voltage, amperage and resistance to each item, with a multimeter.
Old Jan 1, 2016
Bad bulbs and/or sockets?
Old Jan 1, 2016
CraigW's Avatar
This rules out a lot of stuff....
As mentioned inspect the sockets, and bulbs.
Old Jan 1, 2016
Cheddar's Avatar
The hazards work and I replaced the bulbs so it shouldn't be either.
Old Jan 1, 2016
Cheddar's Avatar
REplaced bulbs and hazards work so shouldn't be those
Old Jan 1, 2016
Cheddar's Avatar
Checked the fuse for brake lights and its fine, I have a feeling that there is just a wire somewhere that is loose or damaged.
Old Jan 1, 2016
They use separate bulbs and sockets, completely unrelated..
Brake and tail lights share dual-filament bulbs.
Old Jan 2, 2016
CraigW's Avatar
Get a test light at auto parts store for $5 or less.
Poopies
Lighting DIY
20
Dec 16, 2015 10:10 PM
Hnoob
Oct 22, 2015 07:38 AM
bamahat
Oct 22, 2015 12:11 AM
Enriquepd
Oct 7, 2015 05:43 PM
Junquito89
Oct 7, 2015 03:13 PM
