Brake Drums/Rotors “Rust” removal
Old Oct 7, 2015
Junquito89's Avatar
Junquito89 is an unknown quantity at this point
“What is one of the best ways to remove “rust” from the Brake Drums/Rotors?
Apparently, metal brushes nor any of the other products I've purchased are fit enough to do so (according to a fellow friend!)
Old Oct 7, 2015
MassCivic's Avatar
MassCivic is an unknown quantity at this point
Re: Brake Drums/Rotors “Rust” removal
Drill with some wire wheels should do it. And lots of patience. Keep the brushes off the rotor surface though.
Old Oct 7, 2015
Junquito89's Avatar
Got it! Thanks.
Old Oct 7, 2015
MassCivic's Avatar
And if that should fail try Coca Cola and aluminum foil as a scrubber. All the phosphoric acid in it helps to eat away the rust. Wash well after.
Old Oct 7, 2015
Air powered die grinder with 24 grit Roloc sanding discs will tear up some rust in a hurry.
Old Oct 7, 2015
Junquito89's Avatar
That's great to know as well! Greatly do appreciated! You'll make the app worth using.
Tedverseti
Apr 23, 2020 01:45 PM
Bricoleur
Oct 6, 2015 09:50 PM
Saratoga
26
Oct 2, 2015 09:05 PM
Junquito89
Oct 2, 2015 11:06 AM
Junquito89
Sep 27, 2015 10:22 PM
