Turn Signal
Turn Signal
My brake light no longer works and turn signal no longer works on the left side...The light does turn on though.I've tried multiple bulbs for the turn and brake.The turn signal blinks super fast on my cluster also.its the left side
Fuse maybe?
Fuse maybe?
Re: Turn Signal
Make sure the connection point at the chassis is tight (connector ring terminals are held tight to chassis with screw) You could try removing the screw and terminals and clean grounding area and connectors with some sandpaper and re-secure.
What year are we talking about ??
Re: Turn Signal
Grounds O.K. ??
Grab a cheap 12 Volt test lamp at the auto store. Or a cheap DMM and test if voltages present. Inspect sockets terminals to make sure they are not damaged.
I have the wiring page available if you need it. PM with E-mail address and I can send it to you.
Re: Turn Signal
this might sound a lil dumb i had the same problem in one of my prevent car i own.. it was a wire getting pitch somewhere.. try putting a higher fuse in to the fuse box..
do u have aftermarket side mirriors?? the one with the led lights?
Re: Turn Signal
^ if the wire isnt getting pinched, then a larger fuse will blow the bulbs.
Got a voltage meter? - compare the two sides.
Re: Turn Signal
na i found out the problem last night...its the part you put the bulb to.the little medal pieces inside came off...i had an extra but cant find the biznatch...hope honda doesnt charge too much
steveneddy
May 19, 2015 02:39 PM
my2k1vic
Jan 8, 2002 08:31 PM
