l.e.d. help
Old Dec 29, 2006
XLR8R's Avatar
XLR8R is an unknown quantity at this point
l.e.d. help
hey yall, im tryin to install some l.e.d's under my dash. i want to wire them to my headlights so that when i turn my headlights on they will come on. does anybody know which wire is the one that leads to my headlights? i drive an 02 civic. let me know.thanx
Old Dec 30, 2006
XLR8R's Avatar
is there anyone who can help me with this? please i need to know. thanx
Old Dec 31, 2006
LoneWolf's Avatar
LoneWolf is an unknown quantity at this point
wouldnt it be better to wire it to your parking lights?
Old Dec 31, 2006
CraigW's Avatar
Agree with parking lights instead of headlights. The headlights work by providing common power and grounding to illuminate them. The wire that would have +12 volts with the parking lights on would be RED/YELLOW.
A good source for LED info is LEDs - LSDiodes Optoelectronics
Old Jan 2, 2007
XLR8R's Avatar
dident think of the parking lights. thanx yall. ill try it out and if it works ill post pix.
Old Jan 3, 2007
digitaldemigod's Avatar
2001 Rallye Red EX
digitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of lightdigitaldemigod is a glorious beacon of light
I'm doing this too but I'm splicing off the cigarette lighter and putting in a switch. I wouldn't want that hooked up to headlights.
Old Jan 3, 2007
Alpha 5's Avatar
I actually installed a relay, then pulled the 12V for the switch off of the lighter. That way the lights are on there own circuite. My install was on an undercar kit though.
Old Jan 3, 2007
XLR8R's Avatar
yeh i instaled my driver side one, and i think im suposed to unhook my batery because it compleatly drained it and i had to buy a new one. wouldent even jump for me. is this right?
Old Jan 3, 2007
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
nah, that wouldn't have much to do with it. It'd be easier to splice into your cigarette lighter power source, and hook up a switch. come by and I'll show you mine that I got done bro.
Old Jan 4, 2007
XLR8R's Avatar
awsome dude. will do. pm me ur number i think i lost it. did u do urs urself?
Old Jan 4, 2007
thefever's Avatar
I need a drop
yeah, i did.
Old Jan 5, 2007
whilechukwuzout's Avatar
From: Rochester, NY. Only women are allowed to stalk me tho.
whilechukwuzout is an unknown quantity at this point
Ive found the easiest and best way to do leds is to run a separate cable off of the fuse terminal (12 gauge should do it) directly to a switch. All the leds in the world will not draw enough amperage to warrant a relay.
Then, take out your gauge bezel, and drill a 5mm hole in one of the lower corners and put a low powered led there as an indicator light.
Now, you will not be restricted. You will be able to turn your lights on and off at will, without starting the vehicle. And you will have a reminder when you turn your car off that the light is still on. I have done that and to date, never forgotten to turn my lights off.
Also, be sure to fuse the power supply you use, no matter where it comes from. Hot wires can turn into a fire real quick. And burnt wire insulation is an aweful smell to get out of your car.
zan118
Dec 2, 2011 05:29 PM
becke8
Jul 2, 2011 10:10 PM
meiseman
Nov 23, 2008 04:07 PM
TopFuel
Aug 8, 2006 01:32 AM
CivicHX01
Apr 16, 2003 10:54 PM
