Headlights Issue
Old Nov 21, 2011
zan118's Avatar
zan118 is an unknown quantity at this point
Headlights Issue
I recently bought a 2000 Honda Civic EX, and noticed the headlights are acting weird after I bought it. (lucky me)
On low beams, the left light's off but the l.e.d. ring is on. The right light's on and the l.e.d. ring's off. When I put it on high beams, both outer lights come on, but the inner lights go off. The left inner l.e.d. light is on, but the right isn't. As for the fog lights, the left inner l.e.d. ring is on, but the outer isn't. The right inner l.e.d. ring is off, but the outer is on. The fog lights themselves, the farthest out light bulbs, work fine.
Being an amateur driver, and not knowing anything about Civics, I was wondering how much of this is supposed to be happening and how much of this is a problem that I need to have a mechanic look at. Thanks everyone!
Old Nov 21, 2011
Re: Headlights Issue
sounds like someone did a terrible wiring job. youre gonna have to take them off and see whats going on with the connections and grounds.
Old Nov 21, 2011
96vtech's Avatar
96vtech is an unknown quantity at this point
i have a 96 and there is a seperate fuse for each headlight both high and low have seperate fuses also i was pulling my hair out trying to figure y my hids wernt workin hope this helps a little
Old Nov 21, 2011
zan118's Avatar
Thanks for the info gear and vtech. I had a feeling, but I wanted other people's opinions before I did anything. I figured it might be the wiring or maybe a bad fuse. I'm gonna let a mechanic look at the wiring tomorrow, and hopefully he can shed some light on the subject, and maybe even fix the problem if he doesn't want too much cash.
Old Dec 2, 2011
HondaDr's Avatar
HondaDr is an unknown quantity at this point
Sounds like you have something in backwards on the wiring. Should be a simple fix though. Check your grounds also as a bad ground can cause all sorts of issues.
Old Dec 2, 2011
zan118's Avatar
Thanks everyone! Had the mechanics look at it, they said there was a busted fuse and some bad wiring. Everything's working in it now though! Thanks for the advice!
stryder12
Jun 30, 2015 08:33 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
civic_gt
Apr 19, 2015 08:15 AM
