Trying to retrofit with valeos, help..
Old Sep 4, 2006
  #31
jay78's Avatar
jay78 is on a distinguished road
no ece dont have limiter thing....it has bigger slope....like crazyasian has...
limiter thing is usally on dot shield new one they started after 05 and newer cars on audi....limiter thing should be on both...
Old Sep 4, 2006
  #32
oh okay so the guy i guess got one old and one new projector. mine are 05 and neither one has limiter. any idea why ece has that larger slope?
Old Sep 5, 2006
  #33
seanzee311's Avatar
seanzee311 is an unknown quantity at this point
so wait, that line you have drawn on those shields that look like mine.. thats where i would cut? what should i use, tin snips? does it have to be cut so as to be the same as the other projector, or just trimmed back?
i am going to be doing the retrofit this week/weekend, this is all i need to know. well, im sure i will get stuck at some point on the installlation and have to come ask more questions..
Old Sep 5, 2006
  #34
it would have to be cut the same. you could use metal nibbler from radio shack to get most of it, and then try to make it as exact as possible to the other side with a file. it wont matter that much, since its not as important as the cutoff line. so long as its fairly close to the other side it shouldnt matter. i would just trace a pattern first before cutting.
Old Sep 5, 2006
  #35
jay78's Avatar
when cut make sure u dont go all the way up and shield is not catching any light..if does then u will see a line at the bottom like mine...with limiter...
if u cut bit extra its ok...as long as shield can stay between the blow and lens holder.
i would use dermal kit to cut this
Old Sep 5, 2006
  #36
seanzee311's Avatar
so i can kinda use the one w/o the limiter and trace it onto the other one, then cut. will it matter which side each projector goes on?
and btw thanks for all the help. i will post plenty of pics once i get the retrofit completed.
Old Sep 5, 2006
  #37
i dont think it matters. theyre both pretty much the same.
Old Sep 5, 2006
  #38
jay78's Avatar
it dont matter...like gearbox said..
Old Sep 10, 2006
  #39
SloW4Sh0wVic's Avatar
SloW4Sh0wVic will become famous soon enoughSloW4Sh0wVic will become famous soon enough
those valeos arent great anyway, they have the lines on them
there will be limited color and the beam will not be sharp =\
guess its good if u are in a dark area
Old Sep 10, 2006
  #40
you mean fresneled lens? i have them and its not even noticable. the cutoff isnt as sharp but there arent any weird patterns in the light beam.
Old Sep 11, 2006
  #41
jay78's Avatar
steve yaa fresneled lens thats what is he talking about
i dont like fresneled lens either but they still good....
all new cars now comes with fresneled lens, use to be clear lens but they stooped those, i guess cuz of the colors new TSX dont have clear lens anymore....
Old Sep 11, 2006
  #42
the old tsx looked like ricer lights imo. they were way too bright for some reason either bad aiming or the lens.
Old Sep 11, 2006
  #43
jay78's Avatar
i had new tsx 06 for two day as a loaner for my new MDX
l like there hids not that much colors but bright on the ground...
jody501
Jul 10, 2015 11:01 AM
ImPulse
Lighting
36
Aug 14, 2004 06:08 PM
ser02rav4
Lighting
37
Mar 26, 2004 08:14 AM
ImPulse
Lighting
70
Dec 16, 2003 06:17 AM
