DRL wiring?
Old Jan 22, 2006
DRL wiring?
Does anyone know how to setup a drl system with the front turn signals so they always stay on in bright mode without the other lights being on? I think this would look good. They sell kits but most are around $300
Old Jan 22, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
you want the two amber lights on whenever the ignition is on?
use a relay, you'll have to put wires through the firewall, but thats not a big deal. Or you could tag the parking light wire near the fusebox, but that'll keep the rear parking lights on too.
Old Jan 22, 2006
well its slightly more complicated. i want the two amber turn signal filaments on not the dim parking lights. otherwise i could just turn on the parking light switch lol.
Old Jan 22, 2006
well find the wire that energizes when the turn signal is on and tap into that
Old Jan 22, 2006
its not as easy as you think. what happens then when the parking lights and turn signal are used.
Old Jan 23, 2006
well if your going to be installing the system the front parking lights would become useless, so you could disconnect that wire. You would have to use two relays: one to power up the turn signal filament when the ignition is on and one to cut the power to it when the turn signal indicators are active, letting the car control the turn signal filaments.
Old Jan 23, 2006
oh and how would sidemarkers come into all this?
Old Jan 23, 2006
as long as their tapped into the turn signal line, itll work too
Old Jan 23, 2006
but they would stay on all the time. hmm i'll look into it. thanks for the help.
Old Jan 23, 2006
no problem. keep me posted with any updates, sounds like a cool project
Old Jan 24, 2006
02SILVEREX's Avatar
02SILVEREX has a little shameless behaviour in the past
It's not that complicated...
Parts needed: wire, 2x relay's, per side.
Basicly you would reverse the wires, with some fancy trickery...
You would need to power the relay, and ground it too. I dont remember the voltage for the bulb though... so it gets a little tricky. Basicly you want to switch the input wires. The relays are there to act like a fuse, and regulate the amount of power. I wish I could be more help, but I'm at work right now.
Old Jan 24, 2006
the bulbs are 12v 21w/5w for the signals....
Old Jan 24, 2006
relays acting like a fuse?????
Old Jan 25, 2006
02SILVEREX's Avatar
No not acting like a fuse but a regulator to control the voltage for the differance in wattages.
Old Feb 9, 2006
7thGenerasianCivic's Avatar
http://www.pacificinsight.com/afterm...er_daytime.htm
Try that
SimpleUser
Apr 24, 2021 02:54 AM
Kevinsisco
Aug 31, 2015 12:04 AM
sch2cm
Jul 21, 2015 09:58 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
