Grrrr... glow gauges are not turning on... help!
Old Jan 24, 2005
QBoi's Avatar
Exclamation Grrrr... glow gauges are not turning on... help!
Sorry for posting a second board about this. I took the red wire going out of the glow gauges, cut thru the red/black wire, and wrapped the red wire around it. Then I used electrical tape around that. I took my black cable and tied it around a screw. Turned on my headlights and they will not turn on. It came with a little On/off switch, and that didnt help either.
Old Jan 25, 2005
QBoi's Avatar
Damn
Old Jan 25, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Hey dude post a pic of how you've got it all connected. Did you try connecting the gauge faces to different plugs coming out of the inverter/control unit?
Try a different ground point, see if that helps too. Worst case scenario the control unit that came with your gauges is bad.
Old Jan 25, 2005
QBoi's Avatar
If I had a camera, I would. If I can find one, I'll post up pics.
When I cut the red/black wire, I cut about half an inch off. Does the entire metal wire part of the red wire from the gauges need to be touching the red/black wire, or just some tip?
I did try every single plug, and I reconnected the on/off button, and pressed on the button many times.
My ground was just wrapped around the gauge cluster screw. Does the screw need to be screwed in?
Thanks
Old Jan 25, 2005
gh0st's Avatar
TAQUITOS!!!!
can't hurt to try and put the screw where it's supposed to go.
correct me if i'm wrong, but wasn't the right wire to tap the red one not the red/black?
i exposed about an inch from the wire for the gauges and wrapped it around the wire you're supposed to tap and then wrapped it with electrical tape.
sorry, been a while since i looked behind my cluster.
Old Jan 25, 2005
QBoi's Avatar
The DIY said red/black.
Old Jan 25, 2005
taz757's Avatar
Are you sure you've got a proper ground? You need to have the ring termial pressed up against some bare metal or find a ground in your wiring harness somewhere. I bet you that that's what the problem is.
Old Jan 25, 2005
QBoi's Avatar
Sorry, ring terminal? Whats that?
Old Jan 25, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
did you blow a fuse?
Old Jan 25, 2005
QBoi's Avatar
They are brand new gauges. Needle lights come on, but the gauge doesnt.
Old Jan 25, 2005
TeLLy's Avatar
Dude, you need a ring terminal attached to the end of the black wire, or at least tighten the screw down with some exposed wire on it.
This is a ring terminal:
Old Jan 26, 2005
QBoi's Avatar
Awesome, thanks for the help, I got it all done. But the sucky part is that I have to press the on button AFTER turning on my headlights to get the glow gauges to turn on I mounted the little green on/off button where that steering wheel height lever is.
Old Jan 26, 2005
QBoi's Avatar
My mistake its my ground again I guess. Sometimes it turns on with my headlights, sometimes it doesnt.
Old Jan 28, 2005
TeLLy's Avatar
Find a good ground and make sure your connection to the red/black wire is solid. If you can't find a good ground in the gauge cluster area there are tons of bolts you can use under the dash near the steering column, or even in the center console behind the stereo.
Old Jan 29, 2005
QBoi's Avatar
Meh, my gauge cluster screws are all somewhere within my dash. I have to open up my dash to find the screws so my grounds can work perfect.
Old Oct 14, 2011
osakaboii510's Avatar
osakaboii510 is an unknown quantity at this point
I need help!!
I have a 94 honda civic n i didnt know it was eqiped with a glow gauge till i found out recently when i drove out lastnight and it tunred on n ot actually scared tha heck outta me lol but anyways it turned on for a couple of sec n it turned off nd now itz not turning back on. Please someone help me try n figure out whats the problem??
Old Oct 16, 2011
electric130's Avatar
Re: Grrrr... glow gauges are not turning on... help!
HOLY SON OF A 6 YEAR OLD THREAD!!!!!
jbander
Jun 4, 2015 05:56 PM
HiImBrandon
Jun 1, 2015 07:34 AM
werdnahall
May 17, 2015 11:37 AM
tylerginevan
Apr 27, 2015 12:29 PM
kevin99ek
Apr 23, 2015 09:32 PM
