HID Pic post!!
Old Apr 10, 2005
  #211
ASIANPRIDE's Avatar
GODLIKE
ASIANPRIDE is an unknown quantity at this point
WOW OMFG...that's so hot...*crosses fingers* hope Impulse gets his kits in on Monday...then I can post the pix of me and my buddie....5000k and 6000k kits...
Old Apr 12, 2005
  #212
mikenam's Avatar
mikenam is an unknown quantity at this point
gonna add mine
e46 bixenon projectors
philips d2s 4100k
day time pics of projectors
color at the cutoff
Old Apr 13, 2005
  #213
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
Impulse is using real projectors so it's a D2S swap....
Old Apr 13, 2005
  #214
Rufus's Avatar
I've used ds2 and d2r's in my OEM housings.
Old Apr 23, 2005
  #215
ASIANPRIDE's Avatar
GODLIKE
Ohhhh my kit's in BC.....then once they get here...I will post pix of the Prolumen 5000k and 6000k colored bulbs on my car.....
Old Apr 24, 2005
  #216
dirtySAMURAI's Avatar
I log in from time to time
Old Apr 27, 2005
  #217
ASIANPRIDE's Avatar
GODLIKE
btw: I know there is MAD glare...and can someone please help me find some info on where to get some caspers so I can have a nice cut off line......
thanx...
Old Apr 27, 2005
  #218
ASIANPRIDE's Avatar
GODLIKE
Exclamation
Old Apr 27, 2005
  #219
is there a half shield around the actual bulb on the bottom?
Old Apr 27, 2005
  #220
ASIANPRIDE's Avatar
GODLIKE
^NEG
Does neone have pix of there bulbs+glare shields? I can't comprehend what it looks like...
Old Apr 27, 2005
  #221
ASIANPRIDE's Avatar
GODLIKE
Yes...it's on the bulb...a little black strip....so that the light goes up and not down......
Do you think my problem is because of the lack of a glare shield or bad aiming?
Old Apr 27, 2005
  #222
ASIANPRIDE's Avatar
GODLIKE
Exclamation
I called Caspers Electronics and asked about my Prolumen Rebased H4 bulbs and he said that the shields that they sell will only work for D2S or the D2R HID bulbs and not rebased ones. Sooo looks like the Prolumen kits don't come with shields and tricky aiming will be the only thing one can do to reduce the amount of glare that I'm seeing.....
So the only other option I have is fiding bulbs that will attach to the harness I have and that they have shields built onto the bulb....or I could spend the $65 US and attempt to modify the caspers to fit my h4's with the risk of messing it all up because I would have to remove the current base and find a way to attach the bulb to the Casper base with some sort of glue....so the positioning and aim of the bulbs could be completly off.....
So it looks like Im just going to spend some time aiming the headlamp down as far as it goes....
Old Apr 27, 2005
  #223
mikenam's Avatar
don't hid kits come w/ d2s/d2r rebased bulbs? thats wat thought but im prolly wrong.
Old Apr 27, 2005
  #224
TuRtLE714's Avatar
TuRtLE714 will become famous soon enoughTuRtLE714 will become famous soon enough
you are correct...they are d2s/d2r rebased
Old Apr 27, 2005
  #225
ASIANPRIDE's Avatar
GODLIKE
I think im going to make my own sheilds....
Old Apr 27, 2005
  #226
ASIANPRIDE's Avatar
GODLIKE
what kind of bulbs are these
Because if I mess up trying to attatch my own sheild...then I can just get these ones online....because they have the same power connector ends.....
Old Apr 27, 2005
  #227
i'll try and post a pic later of what the glare shield looks like. It covers the bottom half of the bulb (not touching it ofcourse). Don't know what material it is, but hid does burn alot cooler than halogen.
Old Apr 27, 2005
  #228
turkey baster.
www.hidplanet.com/forums
go to the HIDPLANET university or search for turkey baster mod. it's basically a $5 casper shield that you make yourself. do that and JB weld it to the bulb base
Old Apr 27, 2005
  #229
gh0st's Avatar
TAQUITOS!!!!
those look like rebased d2s bulbs with connectors coming out of it....this should be. i advise what infinite said
Old Apr 27, 2005
  #230
wuddup hoes. new retrofit. it already sucks
ID:	52675   Click image for larger version
ID:	52676   Click image for larger version
Old Apr 27, 2005
  #231
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
The yellow isn't obvious is any of the pics except for the the one of the close up shot of the headlight. Have you figured out whast wrong?
Old Apr 27, 2005
  #232
i have no idea. i'll fix it later though. and the tilted headlight...that one will get fixed later lol
Old Apr 28, 2005
  #233
ASIANPRIDE's Avatar
GODLIKE
Hmmm my one bulb is blueish and the other is more yellow....
Old Apr 28, 2005
  #234
hmm send it back then. I'm assuming its a prolumen kit? I thought those were the good ones.
Old Apr 30, 2005
  #235
duffy2004's Avatar
I F(uck Sheep Naked With My Rubber Boots And _Viper_ At My Side
duffy2004 is an unknown quantity at this point
Originally Posted by ASIANPRIDE
[IMG]
I want my cut off like duffy2004's....how do i do that...do I need to buy caspers? because these kits don't come with them?
I didnt buy anything special, its just OEM housing. But ya i never really thought of it of having a cut off anyways.
Old May 2, 2005
  #236
mikenam's Avatar
heres a short startup video of my Halo headlights retro w/ bmw x5 projectors and Philips Ultinons.
http://home.earthlink.net/~unccvsa/s...x5ultinons.mpg
Old May 4, 2005
  #237
^is that the one with people moaning?
here's some new pics bi-xenon pwns me
ID:	53277   Click image for larger version
ID:	53278   Click image for larger version
ID:	53279   Click image for larger version
ID:	53280   Click image for larger version
Old May 4, 2005
  #238
mikenam's Avatar
i see that you finally have high beams. Was it hard to install the highbeams? With my e46 i had to get a bi-xenon control circuit and then solder a diode. Man your zkw seem like it got a lot of color at the cuttoff. Very nice.
Old May 5, 2005
  #239
it wasn't as hard to get bi-xenons as it was to get the tyc to work properly. and yes, they have a LOT of color at the cutoff. it's orgasmic
Old May 5, 2005
  #240
mikenam's Avatar
did u use any methods to add more color? washer mod? shield bending?
