headlight bulb wattage question?
Old May 30, 2004
streetglower's Avatar
I know our stock bulbs are 65/55 watts. Can we use anything higher like 80/100 watt bulbs without melting the headlight harness?
Old May 30, 2004
Ofcourse. But they will be illegal, and you will need a better wire harness from www.suvlights.com
Old May 30, 2004
will any work with the factory harnesses.
Old Jun 1, 2004
ImPulse's Avatar
yes, it will work but your **** will get ****ed =]
Old Jun 1, 2004
FALKEN's Avatar
Civicforums Junkie
to prevent problems/issues, try to stay with bulbs that draw 60/55
Old Oct 7, 2005
speedracersong's Avatar
ok i just bought nokya hyper yellow h4 bulbs for my car.
theyre rated at 75/80. do i need to buy a wire harness? or am i safe?
Old Oct 7, 2005
tacheon's Avatar
tacheon is on a distinguished road
There's more to consider than melting the harness. The bulbs also put out more heat which can cause the headlamp housing to melt. A wire harness upgrade doesn't address this problem. The only guarantee that you will be safe is if you stick to the stock wattage. Higher wattage headlamps may be okay at highway speeds due to air cooling of the lamp housing, but it may melt when you're at a prolonged stop.
Old Oct 7, 2005
good point. however, i have the nokyas also in my fog lights and they're fine. The nokya are rated higher than they really are. Look on the package and see what the actual wattage is.
Old Oct 7, 2005
it says 70/80w
Old Oct 7, 2005
well i know it says that, but then it also says stock wattage. I checked my fog bulbs and it doesn't even say the actual wattage, only that its "stock." the advertised wattage is what they simulate, not the real value.
Old Oct 7, 2005
IrockCivics's Avatar
sorry to crash your thread, but I have a question... I bought a pair of nokya artic white and they are 100/120w and on the side it says nokya wiring harness recommended... so does that means I cant use these bulbs without a wiring harness?
Old Oct 7, 2005
those will melt your harness. i got a new thicker one for my stock headlights and they are a bit brighter. Thats what you would need but again remember the headlights might melt from the heat even if the wires are heavy duty. www.suvlights.com
Old Oct 8, 2005
CraigW's Avatar
The wiring near the bulb may be bigger with the pigtail sockets... but all the rest throughout the car is still the same. As well as the relays and the switch.
Old Oct 8, 2005
with the upgraded harness? i don't think so. the one i have has thicker wire all around and better relays. its not too noticable, but driving next to another car with stock bulbs, mine has a whiter tint.
Old Oct 8, 2005
so what wattage for aftermarket bulbs for our cars that we dont have to go buy no harness?
Old Oct 8, 2005
55w/60w stock
Old Nov 2, 2005
unsocial's Avatar
I'm not biased, I hate everyone equally!
unsocial is an unknown quantity at this point
I've been running higher wattage bulbs on my stock housing and harness with no problems for 3 years now.
Old Nov 2, 2005
dirtySAMURAI's Avatar
I log in from time to time
remember, people. higher wattage doesn't always mean more light output. HID is 35w, but puts out 3200 lumens
Old Nov 2, 2005
well it does for regular halogen, assuming the bulbs aren't coated. just putting a new wire harness on stock bulbs i noticed mine look whiter than the average car but not the rice white.
Bounddyy
19
Jul 20, 2015 02:42 PM
Kyles24
Jul 16, 2015 10:14 PM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
NoobyKid
Jul 13, 2015 07:53 AM
Kyles24
Jul 12, 2015 09:15 PM
