Sponsored by:
Sponsored by: DashLynx
wiper problem please help
Old 11-19-2013
greg2934's Avatar
greg2934 is an unknown quantity at this point
i have an 04 civic si sedan and i had a problem with my wipers for some time now.... i can turn it on high and use the mist thats it... no low or med... i canged the wiper switch already and didnt make a dif.... need help
greg2934 is offline
Old 11-19-2013
CraigW's Avatar
Re: wiper problem please help
I you use high or mist will it park at low speed as it should ??
Do you have to park it manual ??
CraigW is offline
Old 11-19-2013
greg2934's Avatar
i have to do it manualy
greg2934 is offline
Old 11-19-2013
CraigW's Avatar
Well.... The park uses the low speed windings to perform parking.
Is this a Canada made model by chance ?? (04 Si sedan)
Own a multimeter ??
CraigW is offline
Old 11-19-2013
greg2934's Avatar
i dont own a multi meater and im not shure if its canadian... but my registration sais 04 si and its a 4 door auto... its the wifes car
greg2934 is offline
Old 11-19-2013
I think he meant are YOU in Canada?
An Si up there is an EX down here. (1.7 engine)
An 04 Si down here is a 3 door hatch and has a 2.0 engine.
ezone is offline
Old 11-20-2013
greg2934's Avatar
yea i live in canada... it has the 1.7 vtec... any ideas on the wipers
greg2934 is offline
Old 11-20-2013
CraigW's Avatar
This is a quote from the electrical manual on theory and some wire color info:
With the ignition switch on II battery voltage is applied to the wiper motor through fuse #20 (in the underdash fuse relay box) when you move the wiper switch to LOW, the low speed winding of the motor is grounded through the low contact of the wiper/washer switch, and the wipers run at low speed.
Wire colors: GRN/BLK = +12 volts ign at II
BLU = LOW
BLU/YEL = HIGH
With key at II measure voltage at the BLU lead to see if voltage present…If not you have open low winding or open circuit
CraigW is offline
Domindart
06-04-2015 09:20 PM
pratik05
05-15-2015 01:54 PM
autowill
05-15-2015 11:36 AM
shindrome
Exterior
05-05-2015 02:50 PM
Quick Reply: wiper problem please help
