8th Gen 2006 - 2011.
05 ex parking lights.
Old 10-21-2015
Hnoob's Avatar
Hnoob is an unknown quantity at this point
Hello, new here I tried to find a thread that would help but came up with a blank.
I have a 05 civic ex with a slight parking light problem. Neither the front or rears come on also interior lights for a/c don't either and the dash lights are on full bright( usually dim at night when you turn the headlights on).
I ran out of ideas. So far I've tried; replacing combination switch ,checked relays,checked all fuses(small lights ect.) and nothing has worked. Recommendations ? Please and thank you.
Hnoob is offline
Old 10-21-2015
CraigW's Avatar
Re: 05 ex parking lights.
Do you hear a single click from under dash box while switching them on ??
Have voltage present at the small lights fuse when parking lights are on (there are tiny test points exposed on flat top at each end of fuse)
CraigW is offline
Old 10-21-2015
Hnoob's Avatar
No click so relay? But i checked them already
Hnoob is offline
Old 10-21-2015
Hnoob's Avatar
I have no voltage present but fuse is good.
Hnoob is offline
Old 10-21-2015
CraigW's Avatar
No voltage at fuse #2 (15A) located in under-hood box ??
That fuses source is another larger fuse....but you would likely have other symptoms if it was open.
File Type: pdf
CraigW is offline
Old 10-21-2015
Hnoob's Avatar
yea that's why I'm as confused as you no there's no voltage test light or voltmeter to the fuse. Thanks for the diagram I'll do some more trouble shooting later and see if I find something.
Hnoob is offline
Old 10-22-2015
CraigW's Avatar
Use an alligator clip jumper lead, and clip one side to a sharp tip awl's metal portion. Then use the sharp tip to apply voltage to fuse #2's test points while the other alligator clip is connected to battery positive. (USE CAUTION) (you will be temporarily supplying the missing voltage to that circuit) Have your parking lights on and watch for them up front to confirm.
It sounds as if you have an open between the large main fuse and the small lights fuse.
CraigW is offline
sbi
20
10-23-2015 01:34 PM
Foggy60
05-30-2015 03:51 PM
Ma213802
05-18-2015 07:01 AM
duyaknow
11-23-2001 07:28 PM
NukeSilo
11-04-2001 09:37 PM
Quick Reply: 05 ex parking lights.
