Fuel Pump Relay location -- 2009 Civic
Rep Power: 0 Fuel Pump Relay location -- 2009 Civic
HELP!
I have a 2009 Honda Civic EX 1.8L with 110K miles.
I am trying to replace a fuel pump relay and cannot find a diagram for the under hood fuse/relay box.
Issue: The car has an intermittent problem of not starting. At first, I thought this was a bad fuel pump. Replaced fuel pump and everything was fine for a couple of days. THEN, the same not starting issue came back. If I let it sit for a day, then it will start.
In asking around, I heard about the "main relay" issue in Civics....tried to find the main relay in my 2009 only to figure out it did NOT have one. SO, I am now turning my attention to the fuel pump relay. Bought the part, but don't know exactly which socket it goes into AND there is no clear diagram that I can find.
I am also going to replace the plugs as the car has 110K miles.
ANY help is appreciated -- this seems simple and I am losing patients (with my ineptitude). THANKS!!
Re: Fuel Pump Relay location -- 2009 Civic
Relay for the pump is called PGMFI main relay #2, it's in the dash fusebox, extreme top of the box, center cavity
Rep Power: 0 Re: Fuel Pump Relay location -- 2009 Civic
http://www.autogenius.info/honda-civ...e-box-diagram/
The dash fuse box:
The lower section of the dash pops off to gain access to the upper half of the fuse box
Thanks eZone -- is there anything that could give me a diagram of the whole box?
As mentioned:
1. Replaced the fuel pump...that worked for a while and then the problem started again.
2. Replaced the spark plugs...that worked for a while and then the problem started again.
I would like to replace the under-dash relay, BUT I am not sure if it really exists or it is some mythical unicorn relay.
My mechanic ( a really good guy and mechanic) could not find the problem. Everything worked fine. Got the car back home and the car AGAIN displays the following:
1. Car starts for a short period of time, but quits once put into gear.
2. Next the car will start very briefly then quits.
3. Next, I am just cranking on the engine, doesn't start.
It is _very_ frustrating. If there is ANYONE that has ANY clue I would be REALLY thankful.
As mentioned:
Diagram? I gave you a pic of the whole underdash fuse panel
And I appreciate it a lot. I am just trying to understand what is what. What is the first socket above the fuses? Does whatever that goes in that socket have a part number? I am just looking for a diagram that would go with that picture
I am just trying to fix a problem that seems to appear sporadically.
Thanks -- Truly
Thanks -- Truly
Again, top row center cavity holds the PGMFI main relay #2 for the fuel pump.
In these pics it's green or blue
After you get the piece of dash trim removed you can see this clearly
Parts catalog link (CLICK IT): http://www.hondaautomotiveparts.com/...BIN%29+%282%29
Well....I got the new relay. Figured out how to take off the lower skirt. Replaced the part...AND...still not working.
eZone -- thank you for your help. SERIOUSLY, just showing me the diagram was like talking me off a ledge.
Need to figure out my next move.
Replaced fuel pump. And then it worked for a day.
Replaced spark plugs. And then it worked for a day.
Replaced both fuel pump relays. And that did not do the trick.
Seems like there is a bad relay or short somewhere. All the other electrical systems seem to be functioning.
My driveway is on a slight uphill slant and the problem seems to manifest itself when the temperature drops. Right now I am just reaching for anything.
Thanks again eZone.
Thanks again eZone.
Just a quick update.....because the Honda Civic Gods are pissed at me....the car is now starting.....AAARRGGGHH...
I checked the ignition coil fuse....obviously that's ok...doh
Is there some sort of ignition coil relay?
Thought I was Einstein when I replaced the fuel pump. Now I feel like Elmer Fudd hunting for a pesky rabbit. Pretty confident that it is not fuel related (I hope).
I don't know how you check if a relay is starting to go bad, but I'm now tracking down the ignition coil relay.
I might backprobe a test light into whatever component in the switched circuit is handy.
but I'm now tracking down the ignition coil relay. Relay #2, check the diagram in your fusebox lid and tell us what symbol it has
I have the same issue with Honda Civic 1.6 2007
Could you please tell me what was solution of your car?
Thanks again eZone.
Thanks again eZone.
I have the same exact issue with my civic 1.8 2010. I too, already replaced a new pump still everytime i'm driving the car just stalls out of nowhere. Have you found the culprit yet?
CdXa
12-16-2011 11:10 PM
brucepick
05-24-2010 11:30 PM
boyt911sc
11-12-2008 09:22 PM
midnightblueEX
05-19-2005 03:27 PM
