General 1st - 5th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
multiporpose relay bypass
Old Aug 19, 2018
holdon's Avatar
holdon is an unknown quantity at this point
i think mine is bad. if i apply 12v to the fuel pump it works fine. is this what this relay runs and how do i bypass it. new one is very expensive i also need a wiper motor for the front the old one got water in it as it sat for 15 yrs and broke up. what other years will fit this 1980 civic sw.?
Old Aug 20, 2018
Re: multiporpose relay bypass
Try www.car-part.com
Old Aug 21, 2018
holdon's Avatar
found out it is called the fuel pump cutoff relay and i found my shop manual a little worse for the wear and read about hooking the two black and white wires together and if your pump works with the key on replace the relay. what other year hondas have this relay?
Old Aug 21, 2018
Depending on the construction of the original relay, it may (or may not) be a simple process to adapt a commonly available relay to do the job.
Any idea what's inside the original part?
Old Aug 21, 2018
holdon's Avatar
it is a circuit board. and i have to plug the two black with yellow stripes together and it should fire off the fuel pump.
redgar-atx
19
Dec 6, 2022 03:53 AM
CdXa
Dec 16, 2011 11:10 PM
devlsh1
Nov 24, 2009 09:43 PM
noskid
Jul 8, 2009 11:42 AM
shmik1
Sep 9, 2006 02:49 PM
