SRS Light - Where to begin?
Re: SRS Light - Where to begin?
i thought the SRS light was kind of like your oil light and meant only one thing,
i wil get the codes read,
i disconnected the battery overnight to try to reset it, and the light is still on
oh....so they are not read the same way as CEL codes?
im reading ways to reset the light from under the dash at the yellow wire connector?
will disconnecting the battery reset the SRS light?? like it will the CEL??
You should try searching. There is a sticky in the same section of the forum you posted this.
https://www.civicforums.com/forums/3...srs-codes.html
Only if you have a scanner that can read SRS codes.
Otherwise, follow the links everyone else posted.
Not normally, but in some cases the light may go out on its own after a fault is corrected. Codes may be stored in memory even after the warning light is off.
crazyone64
Sep 14, 2018 07:54 PM
Nycmedic
18
Apr 30, 2016 05:05 PM
