check engine light
Old Jul 8, 2004
tugboat's Avatar
tugboat is an unknown quantity at this point
Unhappy check engine light
my 2001 honda civic check engine light come's on and my RPM will not go above 4000 RPM or no more than 80 mph. Sometime when i shut down the car and restart it it goes away but after a while the problem comes back. Could someone tell me how can I figure out the code for this problem?
Old Jul 9, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
A CODE reader.
Look on ebay, they are around $40. A good tool to have, period.
Old Jul 9, 2004
EManEX's Avatar
EManEX will become famous soon enoughEManEX will become famous soon enough
^ Or you can go to Autozon or Kragen and have them check the code for free.
Old Jul 9, 2004
zen_master's Avatar
^ good idea.
Old Jul 10, 2004
tugboat's Avatar
thanx guys, good looking out
Old Jul 11, 2004
Here are the codes,
obd1
Faulty ECU.
1/2
Oxygen sensor or circuit.
3/5
MAP sensor or circuit.
Crank angle sensor or circuit.
Coolant temperature sensor or circuit.
Throttle angle sensor or circuit./Throttle position sensor
TDC position/crank angle sensor or circuit.
Crank angle sensor or circuit./
#1 cylinder position
Intake air temperature sensor or circuit.
Faulty ECU.
EGR failure.
Atmospheric pressure sensor (BARO sensor) or circuit.
Electronic Air Control Valve or circuit./ Idle air control valve
15
No Ignition output signal. Possible faulty ignitor.
16
Fuel injector circuit.
17
Vehicle speed sensor or circuit.
19
Lock-up control solenoid (auto trans. only)
20
Electric load detector. Possible open or short to ground in ECU wiring.
21
VTEC spool solenoid valve circuit.
22
VTEC oil pressure switch circuit.
30
A/T control unit ECM fuel injection signal "A"
31
A/T control unit and ECM circuit.
41
Heated oxygen sensor heater circuit.
43
Fuel supply system circuit.
48
Heated oxygen sensor circuit D15Z1 engine.
obd2
P0106 5 Manifold Absolute Pressure (MAP) Circuit Range or Performance.
P0107 3 Manifold Absolute Pressure (MAP) Circuit Low Input.
P0108 3 Manifold Absolute Pressure (MAP) Circuit High Input.
P0111 10 Intake Air Temperature (IAT) Sensor Circuit Range or Performance.
P0112 10 Intake Air Temperature (IAT) Sensor Circuit Low Input.
P0113 10 Intake Air Temperature (IAT) Sensor Circuit High Input.
P0116 86 Engine Coolant Temperature Circuit Range or Performance.
P0117 6 Engine Coolant Temperature Circuit Low Input.
P0118 6 Engine Coolant Temperature Circuit High Input.
P0122 7 Throttle Position Sensor Circuit Low Input.
P0123 7 Throttle Position Sensor Circuit High Input.
P0131 1 Primary Heated Oxygen Sensor Circuit Low Voltage (Sensor 1).
P0132 1 Primary Heated Oxygen Sensor Circuit High Voltage (Sensor 1).
P0133 61 Primary Heated Oxygen Sensor Circuit Slow Response (Sensor 1).
P0135 41 Front Heated Oxygen Sensor Heater Circuit Fault (Sensor 1).
P0137 63 Secondary Heated Oxygen Sensor Circuit Low Voltage (Sensor 2).
P0138 63 Secondary Heated Oxygen Sensor Circuit High Voltage (Sensor 2).
P0139 63 Secondary Heated Oxygen Sensor Circuit Slow Response (Sensor 2).
P0141 65 Secondary Heated Oxygen Sensor Heater Circuit Fault (Sensor 2).
P0171 45 System is too lean.
P0172 45 System is too rich.
P0300 Random Misfire.
P0301 71 Cylinder #1 Misfire or Random Misfire.
P0302 72 Cylinder #2 Misfire or Random Misfire.
P0303 73 Cylinder #3 Misfire or Random Misfire.
P0304 74 Cylinder #4 Misfire or Random Misfire.
P0305 75 Cylinder #5 Misfire or Random Misfire.
P0306 76 Cylinder #6 Misfire or Random Misfire.
P0325 23 Knock Sensor Circuit malfunction.
P0335 4 Crankshaft Position Sensor Circuit Low Input.
P0336 4 Crankshaft Position Sensor Range/Performance.
P0401 80 EGR Insufficient Flow Detected.
P0420 67 Catalyst System Efficiency below Threshold.
P0441 92 Evaporative Emission Control System Improper Purge Flow.
P0452 91 Fuel Tank Pressure Sensor Circuit Low Input.
P0453 91 Fuel Tank Pressure Sensor Circuit High Input.
P0500 17 Vehicle Speed Sensor Circuit malfunction (Manual Transmission).
P0501 17 Vehicle Speed Sensor Circuit Range/Performance (Automatic Transmission).
P0505 14 Ignition Control System malfunction.
P0700 70 Automatic Transmission problems.
P0715 70 Automatic Transmission problems.
P0720 70 Automatic Transmission problems.
P0725 70 Automatic Transmission problems.
P0730 70 Automatic Transmission problems.
P0740 70 Automatic Transmission problems.
P0753 70 Automatic Transmission problems.
P0758 70 Automatic Transmission problems.
P0763 70 Automatic Transmission problems.
P1106 13 BARO Circuit Range/Performance.
P1107 13 BARO Circuit Low Input.
P1108 13 BARO Circuit High Input.
P1121 7 Throttle Position lower than expected.
P1122 7 Throttle Position higher than expected.
P1128 5 Manifold Absolute Pressure (MAP) Lower than expected.
P1129 5 Manifold Absolute Pressure (MAP) Higher than expected.
P1149 61 Primary Heated Oxygen Sensor (Sensor 1) Circuit Range/Performance Problem.
P1162 48 Primary Heated Oxygen Sensor (No. 1) Circuit malfunction.
P1163 61 Primary Heated Oxygen Sensor (No. 1) Circuit Slow Response.
P1164 61 Primary Heated Oxygen Sensor (No. 1) Circuit Range/Performance.
P1165 61 Primary Heated Oxygen Sensor (No. 1) Circuit Range/Performance.
P1166 41 Primary Heated Oxygen Sensor (No. 1) Heater System Electrical.
P1167 41 Primary Heated Oxygen Sensor (No. 1) Heater System.
P1168 48 Primary Heated Oxygen Sensor (No. 1) LABEL Low Input.
P1169 48 Primary Heated Oxygen Sensor (No. 1) LABEL High Input.
P1253 21 VTEC System malfunction.
P1257 22 VTEC System malfunction.
P1258 22 VTEC System malfunction.
P1259 22 VTEC System malfunction.
P1297 20 Electrical Load Detector Circuit Low Input.
P1298 20 Electrical Load Detector Circuit High Input.
P1300 71 Multiple Cylinder misfire detected.
P1300 72 Multiple Cylinder misfire detected.
P1300 73 Multiple Cylinder misfire detected.
P1300 74 Multiple Cylinder misfire detected.
P1336 54 Crankshaft Speed Fluctuation sensor intermittent interruption.
P1337 54 Crankshaft Speed Fluctuation sensor - No signal.
P1359 8 Crankshaft Position/TDC sensor Connector disconnection.
P1361 8 TDC sensor intermittent interruption.
P1362 8 TDC sensor - No signal.
P1366 58 TDC sensor #2 intermittent interruption.
P1367 58 TDC sensor #2 signal.
P1381 9 Cylinder Position sensor intermittent interruption.
P1382 9 Cylinder Position sensor No signal.
P1456 90 Evaporative Emission Control System Leak detected (Fuel Tank System).
P1457 90 Evaporative Emission Control System Leak detected (Control Canister System).
P1459 92 Evaporative Emission Purge Flow Switch malfunction.
P1491 12 EGR Valve Lift Insufficient detected.
P1498 12 EGR Valve Lift sensor High Voltage.
P1508 14 Idle Air Control Valve Circuit Failure.
P1509 14 Idle Air Control Valve Circuit Failure.
P1519 14 Idle Air Control Valve Circuit Failure.
P1607 ECM/PCM Internal Circuit Failure A.
P1655 30 SEAF/SEFA/TMA/TMB signal line failure.
P1660 70 Automatic Transmission FI signal A Circuit Failure.
P1681 30 Automatic Transmission FI signal A Low Input.
P1682 30 Automatic Transmission FI signal A High Input.
P1686 31 Automatic Transmission FI signal B Low Input.
P1687 31 Automatic Transmission FI signal B High Input.
P1705 70 Automatic Transmission problems.
P1706 70 Automatic Transmission problems.
P1738 70 Automatic Transmission problems.
P1739 70 Automatic Transmission problems.
P1753 70 Automatic Transmission problems.
P1758 70 Automatic Transmission problems.
P1768 70 Automatic Transmission problems.
P1773 70 Automatic Transmission problems.
P1785 70 Automatic Transmission problems.
P1786 70 Automatic Transmission problems.
P1790 70 Automatic Transmission problems.
P1791 70 Automatic Transmission problems.
P1792 70 Automatic Transmission problems.
P1793 70 Automatic Transmission problems.
P1794 70 Automatic Transmission problems.
P1870 70 Automatic Transmission problems.
P1873 70 Automatic Transmission problems.
P1879 70 Automatic Transmission problems.
P1885 70 Automatic Transmission problems.
P1886 70 Automatic Transmission problems.
P1888 70 Automatic Transmission problems.
P1890 70 Automatic Transmission problems.
P1891 70 Automatic Transmission problems.
Old Jul 11, 2004
tinman's Avatar
OMG! I HOPE you cut and pasted that!
Old Jul 13, 2004
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
HMMMm interesting...i didnt know autozone check codes for ya.
man now i love autozone even more!!!....autozone is better then kragen...and pepboys should go out of business
Old Apr 26, 2009
Honda Power's Avatar
Honda Power is an unknown quantity at this point
Re: check engine light
My honda civic has been recently cutting off while driving and when I restart, it goes for awhile and then cuts off again. The check engine light comes on as well. There's a sensor near the transmission if I press it in, the car moves well until I believe the sensor gets slack again. I got a diagnostic done and it says the TDC Sensor (1) Noise - Code 001 is the problem. Can someone tell me what this sensor is for as I want a second opinion and where is it located in the 2002 Honda Civics (Vti).
Old Apr 26, 2009
TDC = top dead center sensor which is what tells the engine how to run properly. i dont think it has anything to do with trans tho. its around the engine timing area.
Old Apr 26, 2009
Will this sensor cause the car to cut off if it's slack or bad?
Old Apr 26, 2009
mr22508's Avatar
Pistol grip pump in my lap at all times
mr22508 is a jewel in the roughmr22508 is a jewel in the roughmr22508 is a jewel in the rough
Yeah!!! If your not TDC you can really kill yer car dude!!! You can have your valve sticking too far down as your piston reaches its apex at the top and BAM!!! you got to remember we got zero clearance! Bent valves are definetly in your future if your still driving it, im sorry to tell ya!!!
Old Mar 31, 2010
risa74's Avatar
risa74 is an unknown quantity at this point
Hey Tugboat,
I am having the exact issue with my 2001 civic. What did your issue end up being??
Old Feb 22, 2015
Jennifer46's Avatar
Jennifer46 is an unknown quantity at this point
Hello, Right now I'm sick to my stomach with worry. I just bought a 2003 Honda Civic for my daughter Last night. The car drives beautifully, well this morning we started the car up and it act like it wanted to stall, I went up the street and it stopped, went to the store and on the way home the Malfunction Indicator Lamp came on and it hasn't gone off. I took it in and they said codes P0302 and P0303 are misfiring. How in the heck could we drive it last night for the test drive, even took it on the freeway, drove real well and then the next day be doing this? Can anyone Help?
Old Feb 23, 2015
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Read this thread, it may be of some help. Dirty EGR passages...
https://www.civicforums.com/forums/3...-misfires.html
Old Feb 25, 2015
dteresa79's Avatar
dteresa79 is an unknown quantity at this point
Ok I need some help not sure where to post this but I have a 2001 Honda civic lx just spent 1800.00 on replacing the head gasket and not 2 days later my check engine light came on with these codes P1486 P0116 P0128 what is this how do I fix it do not want to have to replace the head gasket again so stressed!!!
Old Feb 25, 2015
bsmiley's Avatar
Search the forum for the fault codes you listed and read the threads.
I searched P1486 and this page was one of the results:
https://www.civicforums.com/forums/3...i-codes-2.html
From reading the codes it might be a good idea to check your ECT sensor. The reason I suspect this is because of the P0116 code: "Engine Coolant Temperature (ECT) Sensor Circuit Range/Performance Problem"
So search for ECT sensor in the 7th gen forum and see if you can test the sensor.
You can also download the repair manual in the most current link of this thread and search for the "ECT sensor" in the pdf manual (ctrl+f):
https://www.civicforums.com/forums/1...e-updated.html
Looks like you'll have to have a scan tool to see if the output from the sensor is valid.
But if the sensor is bad, you can get a genuine OEM sensor from Majestic for about $50.
http://www.hondaautomotiveparts.com/...SENSOR+%281%29
Old Feb 25, 2015
Return to the shop that did the work, apparently they aren't finished.
They could have damaged the sensor, they could have not got it plugged in all the way, stuff like that.
For P1486 and P0128, they are likely caused by the P0118 coolant temp sensor fault.
Is the ECT not plugged in all the way?
If P1486 and P0128 return again after fixing the P0118 code, that will be another issue.
Xuhme
21
Aug 7, 2023 03:40 PM
hernandexz
Oct 28, 2021 10:52 PM
jetcare101
May 8, 2015 01:33 PM
tylerginevan
Apr 27, 2015 12:29 PM
bahena08
Apr 11, 2015 05:09 PM
