Hydrolocked or NOT!?!?
Old Jun 15, 2003
Civic2k2Ryder's Avatar
Civic2k2Ryder is an unknown quantity at this point
Question Hydrolocked or NOT!?!?
The other day it was raining like hell. I was going aroung the back side of K-Mart and drove through what looked like a shallow puddle. The shallow puddle was deeper than it looked. I drove through and my car shut off and locked down. I had my car towed to my garage. I looked around for an answer to my problem. I found out that i probally had hydrolocked my car. The symptoms sounded the same. CAI with no bypass valve sucked water into the engine. so far the car is locked up from what i can tell. I took off the spark plugs and released the compression and tried to crank the car. Nothing. I then drained the oil and water that ran through the engine. I then ran motor flush through it. Now we are trying to manually turn over the engine. Under the driver side wheel well there is a bolt to turn the engine over it wont budge. I need some help trying to loosen something up to get the engine to turn over. So far i have decided to take off the oil pan and look and see if a rod is bent. And I want to loosen up the belts too, to loosen up the tension. SO if you can tell me other ways that would possiblly help me make a suggestion.
Old Jun 16, 2003
flotsamm's Avatar
Dayum.. if you took the sparks plugs out already, it should turn over fairly easy with socket and rachet with the tranny in neutral since there isnt any compression...
Old Jun 18, 2003
the engine is completly locked up nothing is lettign it loose. we are slowly taking everything off the engine. I guess im stuck rebuilding engine. but i am having it bored 60 over and replacing everything, so later the engine will hold to a high shot of NOS.
jjdawg22
Aug 15, 2005 10:59 PM
bgoetz
May 31, 2005 01:46 PM
NoToRiOuSxPiNoY
Aug 26, 2003 07:36 PM
DaPipeLayer
Jul 18, 2003 04:46 AM
jpan_home
18
May 6, 2003 09:59 AM
