odometer fraud
Old May 5, 2003
yoshi's Avatar
yoshi is an unknown quantity at this point
Question odometer fraud
Hey, how would you know if anyone is doing odometer fraud(like stopping their odometer reading). I wanted to buy a used car and I want to know how to find this out...
Any info regarding odometer fraud, post it here please. Thanks.
Old May 5, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
carfax.com
Its pretty hard to screw with an electronic odo... the ECU keeps track.
Old May 5, 2003
Darko's Avatar
Darko is an unknown quantity at this point
digital odometer its a lot harder to stop or adjust milage but if its regular style odometer if it was messed with you can tap top of dash right above odometer and if numbers jiggle Guess what its been adjusted. Also some people who do their own service on the car and dont take it to dealer who records milage after a while they go to junk jard and buy odometer with less miles. so be carefull.
Old May 5, 2003
dirtEsanchez's Avatar
Better Then God
dirtEsanchez is an unknown quantity at this point
Originally posted by Boilermaker1
carfax.com
I always here conflicting arguments on that one...people always argue that the ECU doesn't keep track then others say it does....
I'd say it doesn't since ECU stands for Emissions Control Unit, I'd say all it does is takes the RPM's of the engine and controls air flow and fuel flow based in that, called a fuel map...I don't think it has anythign to do with Mileage....
Old May 5, 2003
flotsamm's Avatar
I believe it stands for Electronic Control Unit... but yeah its debatable on what keeps track. I think it varies depending on the make. I know that when you swap out the instrument cluster out of our cars they make you put a sticker on your door jamb to show the correct mileage.
Old May 5, 2003
DizWikedCivic's Avatar
you can check the vin number of the car
Old May 5, 2003
yoshi's Avatar
So basically, the way to check is run a vehicle report using the vin. How does the vehicle history report able to get that info if the owner of the car changes his own oil and everything? Is that always accurate or will I be able to get ripped off regardless of the Vin number checkup?
Old May 5, 2003
everytime they smog your car they record your mileage
Old May 5, 2003
Wanger's Avatar
Wanger is an unknown quantity at this point
ding ding ding BINGO
thats the best way to find out if the odo been f'ed with.
Old May 6, 2003
WannaBFast's Avatar
Prowlin' with a Purpose
but what of the states that dont have smog tests? and most ppl that wanna puts with the odo... they change the entire gauge cluster
Old May 6, 2003
silverdevil's Avatar
silverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of lightsilverdevil is a glorious beacon of light
First of all, the ECU stands for Engine Control Unit.
Secondly, any time you service your car at the dealer, smog it, or do any maintenance at any one of many locations, your mileage is noted. As for the numbers jiggling when you tap your dash, that only happens if it's done the wrong way. You might also see a line thru the numbers, it's quite thin so look carefully. Many manufacturers use that as a sign of tampering.
Oh, and the ECU doesn't keep track. That's a mith. If you disconnect the speedometer cable and run your car, and then reconnect it, you will notice your mileage hasn't changed. The memory is only kept in the odo itself.
Old May 6, 2003
Civic2k1racer's Avatar
Civic2k1racer is an unknown quantity at this point
my friend told me about a year ago that if u take it to a gas station, they can put it on a machine that tells u how many miles the engine has? i dunno if its true anybody hear of this??
Old May 6, 2003
RedDragon333's Avatar
never heard of this one. Not sure if its actually true
Old May 7, 2003
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
I think thats a federal offense, i will look it up for you guys to make sure. I am sure it varies from state to state.
Injen
Old May 7, 2003
Connie's Avatar
I thought it stood for Eat Connies Unit.....
Old May 7, 2003
Connie's Avatar
Injen
If it is a federal offense it would not differ from state, it would be national
Old May 7, 2003
slammed2k2's Avatar
slammed2k2 is an unknown quantity at this point
im pretty sure if you swap your gauge cluster, then the ECU will not keep track and it is not tracable!
Old May 7, 2003
spookini's Avatar
spookini is an unknown quantity at this point
"my friend told me about a year ago that if u take it to a gas station, they can put it on a machine that tells u how many miles the engine has?"
What do you think they do, carbon-date it????
Old May 9, 2003
slammed2k2's Avatar
LOL! thats jokesss!
hehehehehe
Old May 9, 2003
sexcivic2k1's Avatar
HAHHA GOOD ONE!
Old May 12, 2003
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Yeah, I was under the impression that OBD-II (on board diagnostics) kept track of milage. Thats what the wierd looking 'port' is under the drivers side of the dash of every car made in the last 10 years. I could be wrong though.
Old May 12, 2003
slammed2k2's Avatar
i would think that you are wrong!
sorry
Old May 12, 2003
Zzyzx's Avatar
Autocross Junky
There is a chip attached to the Odometer that counts up, to change it you need to purchase a new chip. to get a new chip, you first need to find out what type of chip it is, and serch for that same chip at an electronics store (Some Manufacturers use Generic chips) or some how aquire one from the factory (Highly Improbable). Now that you have the blank chip, you need to program it to accept the cars signals and interprit them properly (requireing special equipment) so with an electronic odometer, it is not impossable, just improbable due to it being such a pain in the *** to do.
hondacivic0253
Sep 29, 2015 08:06 AM
Donahue
Sep 9, 2015 05:55 PM
msaeger
Sep 2, 2015 08:47 AM
NoobyKid
Jul 18, 2015 02:01 PM
