Rust spot on the door..anything that will help get rid of it?
Old Feb 10, 2003
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
I have a decent sized rust spot on my passenger door (didn't know about the scratch for awhile...its on the passenger side...). Are there any chemicals that I could treat it with to eat away the rust? I would like to do that so I could touch it up a bit.
Old Feb 10, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
The warranty. Provided of course that there's less than 36K on the car... there's a warranty on body panel rust. I don't know if you can chemically treat it and eliminate it. I know steel wool or scotchbrite will get the job done, but you'll need to paint it after that.
Old Feb 10, 2003
nbpEMCivic's Avatar
I didn't think the warrenty is going to cover scratches.
Old Feb 11, 2003
blouisgod's Avatar
Life Begins > 6800rpms
if you have some dents, id just go to a body shop and have it fixed. you're right, that wouldnt be covered under warranty.
Old Feb 11, 2003
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Yes I would go to the dealership and give it a try and see if they can or will do anything for you, its worth a shot. And if not then you should take it to a shop somewhere ASAP, that stuff is cancer to cars and will only get worse.
Good Luck man.
Old Feb 11, 2003
LiLaSiiAn8's Avatar
yea, i thought the warrenty covers rust. i could've swore that the pple told me it was covered. cuz rust.. thats like old school. anywho, take it bak, i hope they fix it for you!
Old Feb 11, 2003
XxJDMCivicxX's Avatar
If it's caused by a dent or scratch I doubt it i'll be covered by warranty because when you dent your car or scratch it it rusts faster than normal, my physic teacher told me something about dents and oxidization for some reason it affects the area that is dented and will deteriorate faster can't remember why though.
Old Feb 11, 2003
LiLaSiiAn8's Avatar
Quote
[hr]Originally posted by: XxJDMCivicxX
If it's caused by a dent or scratch I doubt it i'll be covered by warranty because when you dent your car or scratch it it rusts faster than normal, my physic teacher told me something about dents and oxidization for some reason it affects the area that is dented and will deteriorate faster can't remember why though.[hr]
0o0o.. i didn't know that! i really thought rust was like a thing of the past, i guess not. so i guess what the dealer meant is they'll cover it if it starts rusting by itself? hmm.. hahaha
Old Feb 11, 2003
nbpEMCivic's Avatar
Correct, if it starts rusting by itself they would have to cover it under warrenty. But in my case it is a scratch that left the metal exposed. I figured it would be ok if I just somehow removed the rust and went over it with some touch up paint. Has anybody used the touch up paint before?
Old Feb 11, 2003
kjgracing's Avatar
Hail to the king baby
kjgracing will become famous soon enoughkjgracing will become famous soon enough
you can get this at hardware stores/home improvement
Naval Jelly-- Best Rust remover Ever!!
Description
For safe and easy removal of rust from iron and steel. Naval Jelly is useful for preparing metal surfaces for painting. Paint will adhere better to iron and
steel surfaces when cleaned will Naval Jelly. It is also an ideal pretreatment for all galvanized surfaces prior to painting.
Technical Information
Appearance: Clear Viscous Liquid
Solubility: 100%
Density: 8.67Lbs./Gal.
pH Level: 1
Odor: Mild
Rinsing: Complete
Flash Point: None
Stability: Stable
Foaming: Moderate
Directions
For general cleaning of iron and steel, apply full strength with a paint brush, roller or sponge. Allow a dwell time of 5 to 20 minutes depending on the amount of rust to be removed. If heavy encrustations are present, use a wire brush to clean before applying. In severe conditions, it may be necessary to apply Naval Jelly several times. If this occurs, allow a longer dwell time, overnight if possible.
Material Safety
This product is for industrial and institutional use only. Corrosive, contains phosphoric acid.
Old Feb 11, 2003
nbpEMCivic's Avatar
Thats what I'm looking for! I'll go get a bottle tomorow. Thanks.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
mightbuyacivic
General 8th & 9th Gen
Sep 26, 2015 09:43 PM
Bikergofast
Sep 12, 2015 01:36 PM
