Rust spot on the door..anything that will help get rid of it?
I have a decent sized rust spot on my passenger door (didn't know about the scratch for awhile...its on the passenger side...). Are there any chemicals that I could treat it with to eat away the rust? I would like to do that so I could touch it up a bit.
The warranty. Provided of course that there's less than 36K on the car... there's a warranty on body panel rust. I don't know if you can chemically treat it and eliminate it. I know steel wool or scotchbrite will get the job done, but you'll need to paint it after that.
if you have some dents, id just go to a body shop and have it fixed. you're right, that wouldnt be covered under warranty.
Yes I would go to the dealership and give it a try and see if they can or will do anything for you, its worth a shot. And if not then you should take it to a shop somewhere ASAP, that stuff is cancer to cars and will only get worse.
Good Luck man.
Good Luck man.
yea, i thought the warrenty covers rust. i could've swore that the pple told me it was covered. cuz rust.. thats like old school. anywho, take it bak, i hope they fix it for you!
If it's caused by a dent or scratch I doubt it i'll be covered by warranty because when you dent your car or scratch it it rusts faster than normal, my physic teacher told me something about dents and oxidization for some reason it affects the area that is dented and will deteriorate faster can't remember why though.
Quote
[hr]Originally posted by: XxJDMCivicxX
If it's caused by a dent or scratch I doubt it i'll be covered by warranty because when you dent your car or scratch it it rusts faster than normal, my physic teacher told me something about dents and oxidization for some reason it affects the area that is dented and will deteriorate faster can't remember why though.[hr]
Correct, if it starts rusting by itself they would have to cover it under warrenty. But in my case it is a scratch that left the metal exposed. I figured it would be ok if I just somehow removed the rust and went over it with some touch up paint. Has anybody used the touch up paint before?
Hail to the king baby
you can get this at hardware stores/home improvement
Naval Jelly-- Best Rust remover Ever!!
Description
For safe and easy removal of rust from iron and steel. Naval Jelly is useful for preparing metal surfaces for painting. Paint will adhere better to iron and
steel surfaces when cleaned will Naval Jelly. It is also an ideal pretreatment for all galvanized surfaces prior to painting.
Technical Information
Appearance: Clear Viscous Liquid
Solubility: 100%
Density: 8.67Lbs./Gal.
pH Level: 1
Odor: Mild
Rinsing: Complete
Flash Point: None
Stability: Stable
Foaming: Moderate
Directions
For general cleaning of iron and steel, apply full strength with a paint brush, roller or sponge. Allow a dwell time of 5 to 20 minutes depending on the amount of rust to be removed. If heavy encrustations are present, use a wire brush to clean before applying. In severe conditions, it may be necessary to apply Naval Jelly several times. If this occurs, allow a longer dwell time, overnight if possible.
Material Safety
This product is for industrial and institutional use only. Corrosive, contains phosphoric acid.
Description
Solubility: 100%
pH Level: 1
Odor: Mild
Rinsing: Complete
Flash Point: None
Stability: Stable
Foaming: Moderate
Directions
Material Safety
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
mightbuyacivic
General 8th & 9th Gen
Sep 26, 2015 09:43 PM
Touge
Sep 23, 2015 10:51 PM
Touge
Ottawa
Sep 22, 2015 11:58 PM
Bikergofast
Sep 12, 2015 01:36 PM
