Racing Seats and SRS light
Im getting the tenzo r seats soon and i was talking to one of my buddies and he said that i might have to reset the srs light if i take the seats out to swap them, is this correct??...let me know before i get them so it wont be a hassle.thanx
I got the same seats and if you have side airbags the light will go offf, and make sure you get the sliders and brackets made for the 7thgen otherwise your gonna have a he!! of a time.
good thing red dragon has those seats or else you would have to [IMG]i/expressions/moon.gif[/IMG] bend over and get screwed cause your light would be going off all the time...
INJEN
INJEN
just make sure you leave the ignition off, don't even have the key in the on position and you shouldn't have a problem with your srs light. disconnect it, swap the seats, and then turn the car on, the srs light should not stay on...do the tenzo seats really fade???
Quote
[hr]Originally posted by: HondaSales
just make sure you leave the ignition off, don't even have the key in the on position and you shouldn't have a problem with your srs light. disconnect it, swap the seats, and then turn the car on, the srs light should not stay on...do the tenzo seats really fade???[hr]
Quote
Quote
[hr]Originally posted by: cdmx
I reset my srs light with a paperclip
[hr]
[hr]
How do we bypass the SRS? My seats come in this week.
Quote
[hr]How to reset your SRS light on your civic. This works for 99-00 Civic's as well as 2k1's. What is pictured is actually a 2k1 but the plug for the 99-00's are in the fuse box also, just on the other side of the column.
1st you need to either buy or make the "SCS Service Connector." I used a speaker harness for and older Honda which you can buy at a local stereo shop such as Circuit City or Best Buy, and cut the wires and looped them together. You can also use a paperclip but that will make it a little more difficult because you have to connect it and disconnect it a few times quickly.
2nd you need to find the MES (Memory Erase Signal) connector which is pictured below: (Click to enlarge)
MES Plug in Fuse box.
SCS Plug
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
[hr]
SCS Plug
[hr]
Burnout
Jul 15, 2022 10:24 PM
Blazz
May 25, 2015 10:56 PM
jimmyfloyd
May 20, 2015 07:06 PM
