Need help with exhaust work...removing custom cat back...
Old Oct 16, 2002
nbpEMCivic's Avatar
nbpEMCivic is an unknown quantity at this point
Ok, our first attempt at switching our exhaust systems is detailed here. I got a tool that should solve my stripped nut on the cat problem (or at least the wise old man at Home Depot told me so). What would be the best way to remove my exhaust piping after I get it unbolted from the cat? I'm going to be working on it in a garage using jackstands. Keep in mind that the exhaust system after the cat is one piece (its custom 2.25" piping with an Arospeed muffler welled on at the end). Is it possible to just slide it all out through the rear? I don't know if it will fit past the rear sway bar? Or past the rear bumper. Any suggestions guys? I have some good pics that might help in my member's ride section.
Old Oct 16, 2002
macrossranma's Avatar
macrossranma is an unknown quantity at this point
how many pieces is it from the cat to the muffler?mine came in 3 piece, all connects with u clamps easy to take off
Old Oct 16, 2002
SleeperCivic's Avatar
SleeperCivic is an unknown quantity at this point
Well, all I can say is keep in mind once you unbolt it you might be able to slide it out forward instead of the whole thing out the rear?? You'll need to take a look at this. You just might have to cut it... Good luck though.
Old Oct 16, 2002
nbpEMCivic's Avatar
Quote
[hr]Originally posted by: macrossranma
how many pieces is it from the cat to the muffler?mine came in 3 piece, all connects with u clamps easy to take off[hr]
Quote
[hr]Keep in mind that the exhaust system after the cat is one piece (its custom 2.25" piping with an Arospeed muffler welled on at the end).[hr]
Old Oct 16, 2002
yeah, i say take off the bolts and carefully slide it to the back, thats the only way
kmarcet
Sep 26, 2015 10:25 PM
USCGBM
Aug 12, 2015 04:22 PM
PierrePierre
Aug 12, 2015 02:42 PM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
Theshwartz35
Jul 17, 2015 11:13 PM
