High Rpm Low engine speed/hesitation
Old Feb 7, 2023
poop.em2's Avatar
poop.em2 is an unknown quantity at this point
I have a 2005 civic ex which i just changed the spark plugs in, it hesitates when accelerating noticed the issue like 3 days ago, also saw a lil bit of oil in my first cylinder from the left but the other 3 were dry, theres no codes but maintenance req’d light is on it’s stressing me out please help 🙂
Old Feb 7, 2023
Colin42's Avatar
Re: High Rpm Low engine speed/hesitation
What brand of plugs? What's your trans fluid look like?
Old Feb 27, 2023
poop.em2's Avatar
Denso Spark Plugs and trans fluid looks good
I do have P0128 and P0420 so yea but it might be due to the coolant stuff
Old Feb 27, 2023
Colin42's Avatar
If the engine isn't seeing the correct temp that could cause an issue. So can a clogged cat
Old Feb 27, 2023
P0420?
your cat want to fart, uncork it
"High Rpm Low engine speed" are contradictory
Old Feb 27, 2023
poop.em2's Avatar
Originally Posted by sdaidoji
P0420?
Lol yea working on that
Old Feb 27, 2023
poop.em2's Avatar
Temp jumps up and down I just got a new radiator and thermostat too so i’m not sure what the hell is going on
Old Feb 27, 2023
BrotatoChip's Avatar
Super Moderator
Was the coolant properly bled? Are you having overheating issues?
Old Feb 27, 2023
poop.em2's Avatar
Coolant was bled when i swapped radiators and I am beginning to have overheating issues
Old Feb 28, 2023
Super Moderator
Leaking coolant? Reservoir tank overfilled and/or overflowing?
Old Feb 28, 2023
poop.em2's Avatar
I know the hose from the reservoir tank by the radiator cap was leaking but i got a hose clamp to closed it so its not leaking anymore
Old Feb 28, 2023
Super Moderator
Radiator level low? Reservoir tank overfilled?
Old Feb 28, 2023
poop.em2's Avatar
reservoir tank is not overfilled and i filled the radiator a couple days back
Old Mar 1, 2023
Super Moderator
I was thinking head gasket, very common on this generation Civic. Would cause overheating and possibly other issues. Radiator level would always drop when driven, reservoir level would rise until it overflowed. Maybe not your issue.
flyagaricus
Apr 23, 2021 12:54 PM
bohrapar
Nov 3, 2020 09:01 AM
htc1x
Feb 23, 2017 08:29 PM
Nalmonte
Jan 23, 2016 05:55 PM
ModNewbieHELPME
Nov 30, 2001 06:13 PM
