High Rpm Low engine speed/hesitation
I have a 2005 civic ex which i just changed the spark plugs in, it hesitates when accelerating noticed the issue like 3 days ago, also saw a lil bit of oil in my first cylinder from the left but the other 3 were dry, theres no codes but maintenance req’d light is on it’s stressing me out please help 🙂
Re: High Rpm Low engine speed/hesitation
If the engine isn't seeing the correct temp that could cause an issue. So can a clogged cat
I was thinking head gasket, very common on this generation Civic. Would cause overheating and possibly other issues. Radiator level would always drop when driven, reservoir level would rise until it overflowed. Maybe not your issue.
bohrapar
Nov 3, 2020 09:01 AM
htc1x
Feb 23, 2017 08:29 PM
