Weird Bogging When Cold (Video) [solved]
Old Dec 28, 2022
sd424977's Avatar
sd424977 is an unknown quantity at this point
Hey guys, new here. My dad's 2005 Civic started having this problem. It only happens in the beginning, but once the car is warmed up it's gone. It feels like the engine is bogging, and sometimes to the point where it drops completely but the car doesn't turn off. Ignore the whining noise, that's just the failing power steering pump. You can kind of hear the engine mini bogging.
UPDATE 1/11/2023
The problem turned out to be a faulty coil pack.
Old Dec 28, 2022
GolNat's Avatar
Prelude Owner
re: Weird Bogging When Cold (Video) [solved]
How many miles? When were the plugs done?
Old Dec 28, 2022
sd424977's Avatar
About 250k miles. We bought new spark plugs because we thought that was the problem. But I don't think the spark plug wires haven't been changed, except for one.
Old Dec 28, 2022
sd424977's Avatar
Old Dec 28, 2022
GolNat's Avatar
Prelude Owner
Wires don’t get replaced since it has coil packs. If you only did one I’d replace them all and check the gap on the new plugs. NGK or Denso no Bosch plugs.
Old Dec 28, 2022
sd424977's Avatar
I see. Yeah that’s what I meant, only one coil pack was replace a while ago. Should I really just replace all of them? Can’t I do tests to see which one isn’t working? Also, since it only happens when it’s cold, can that still be a coil pack issue? Shouldn’t it be consistent all throughout?
Old Dec 28, 2022
GolNat's Avatar
Prelude Owner
I’m talking about the spark plugs.
So you did replace all 4 spark plugs and 1 coil pack?
Yes typically a bad coil pack will stay bad and you check them by unplugging them and seeing if the engine runs worse.
Old Jan 11, 2023
sd424977's Avatar
Hey, sorry for the late reply but it turned out to be a faulty coil pack. Thanks for the help!
Millsy088
Electrical
Jan 14, 2022 04:12 AM
2005-civic-vp
Air Conditioning
Jun 17, 2021 02:53 AM
vboss5764
Apr 22, 2021 11:01 PM
cdmx
Apr 24, 2003 01:03 PM
AllMotorSi
Oct 6, 2002 10:03 PM
