Squealing noise when starting car
Old Feb 15, 2022
beltinck625's Avatar
beltinck625 is an unknown quantity at this point
I've looked around online and come to the conclusion that the very loud squealing noise I'm hearing must be coming from the alternator belt being a little loose. Supposedly that is common in the winter as it gets pretty cold.
Anyways, I'm not much of a car guy and don't have any experience working under the hood other than jumping the car a few times. How hard is it to adjust the alternator in order to tighten the belt? and how would I do that?
Before I do too much work, I should ask, would spraying a little WD-40 on the belt have any effect? hoping for an easy solution to the problem.
Old Feb 15, 2022
Re: Squealing noise when starting car
if you try to do it, don't leave any of the bolts loose. Check the next day, another after a week.
(Loose alternator bolts fry the ECU, it will be expensive if you screw that one)
Old Feb 15, 2022
Colin42's Avatar
There's most likely a YouTube on how to do the belts. Make sure all the bolts are tight or you will fry the ecu.
Old Feb 15, 2022
FRSam's Avatar
Click Here
I'd check the power steering belt first. That acted up on mine and was pretty bad at idle before I fixed it.
Old Feb 16, 2022
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Along with the above suggestions, there is an alternator adjustment bolt that can become stripped and will need to be replaced - been there done that.
Old Feb 17, 2022
GolNat's Avatar
Prelude Owner
Don’t spray WD40 on it unless you wants to make it worse. The belt is slipping so you need to add friction to the belt.
If it’s suppose to move and doesn’t use WD40
If it’s moving and it’s not suppose to duct tape or JBWeld
tom1988
Aug 2, 2020 12:37 PM
Kyleprice2118
General 1st - 5th Gen
Oct 26, 2019 08:58 PM
dalaw
Sep 22, 2011 11:11 PM
lexxie
Oct 16, 2009 12:12 AM
hnperez5
Jul 14, 2007 09:24 PM
