2007 honda civic wont rev past 3500 rpm
my car started to bug a little back so i decided to check what was wrong, and so i changed my air filter. then i thought it was maf sensor so i bought a new one changed it. same problem. then i decided to give a throttle body a good clean. still didnt solve the problem. then one of my freinds siad to check my spark plugs, and they were shocked so i changed and still didnt fix my problem. i plugged the machine and the codes that its throwing at me are p0113 and p0102. do you guys think that the maf sensor is faulty or its something comepelty different.
Re: 2007 honda civic wont rev past 3500 rpm
Might be the
-IAT sensor
-MAF
but you should also check the basics first
-grounds
-battery terminals
-fuses
-relays
if all related fuses and grounds check out, it's also good to check the wiring to the sensors, as a rat could have chewed one. There are wiring testing procedures on youtube.
-IAT sensor
-MAF
-grounds
-battery terminals
-fuses
-relays
Dustin19902
Aug 10, 2014 08:00 PM
RemyL31
Mar 24, 2011 07:09 PM
