2004 d17a2 connecting rod bearings - what color?
Old Mar 4, 2018
j00fek's Avatar
j00fek is an unknown quantity at this point
04 civ 175K
pulled the motor for rebuild and im looking for the correct color connecting rod bearings, honda lists many different colors not sure if mine is red or orange? how would i know what correct rod bearing to select?
Old Mar 4, 2018
j00fek's Avatar
Re: 2004 d17a2 connecting rod bearings - what color?
Old Mar 4, 2018
j00fek's Avatar
looks like one should rtfm.....lol
found it on pg 7-10
Old Mar 4, 2018
RobertD's Avatar
RobertD is a jewel in the roughRobertD is a jewel in the roughRobertD is a jewel in the rough
i have a possibly dumb question... did you look at the back side of the bearing shell? every bearing i've ever seen has numbers printed on the back.
Old Mar 4, 2018
Slumpertcivic's Avatar
Those actually look fine, why replacing them?
Old Mar 4, 2018
j00fek's Avatar
i see brass? and / or wear so i got a new set, crank looked good.
oil rings were clogged as usual , soaking in carb cleaner now.
Old Mar 5, 2018
The important thins are the micro grooves which as still visible, lack of gouges, and no color change.
One few times I actually worry about putting clean gloves on, you don’t want anything between the bearing and the rod.
Also highly suggest leaving the spark plugs out, pulling the ECU fuse and cranking over in 30 sec bursts till your pressure light goes off and then one more burst for insurance.
Puccillo
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Jan 15, 2018 10:32 AM
civicsrcool
Apr 4, 2010 04:56 PM
CvC-v01
Jan 30, 2004 10:12 PM
Grey
15
Aug 25, 2002 12:13 PM
Chuck94527
Jan 31, 2002 07:49 AM
