Alternator fuse#4 keeps popping
Old Mar 4, 2018
ChaosUnleashed's Avatar
ChaosUnleashed is an unknown quantity at this point
hey every I have a 2005 Honda Civic 5 speed. My alternator fuse keeps popping after a few minutes of car running thus causing the alternator to stop working and my battery dies shortly after any idea what could be causing this ive replaced alt and battery just to be on the safe side and no change what can I do to fix this
Old Mar 4, 2018
Re: Alternator fuse#4 keeps popping
Disconnect plug from alternator. Run engine. Does fuse still blow?
If you have a wiring diagram you would see the ALT fuse #4 covers far more than just the alternator:
AF heater relay
O2 heater
ELD
Cruise switch, actuator, and control unit
VSS
EVAP PURGE, CVS, and BP solenoids
*This is not a shopping list of parts to replace.
This is a list of things to inspect and test.
Don't ignore the wiring.
Old Mar 5, 2018
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
Check the wires to the O2 sensor. I had a heat shield come loose and wear thru the wires to the O2 sensor causing that fuse to blow.
Old Mar 5, 2018
D17VTECPOWER's Avatar
D17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of lightD17VTECPOWER is a glorious beacon of light
AF heater relay
O2 heater
ELD
VSS
This. My o2 sensor wires shorted out and kept blowing the alternator fuse too.
rstephe
Nov 4, 2012 12:17 PM
03ex4dr
Jan 21, 2009 12:12 PM
ShoelessEX
Engine Swaps
Apr 11, 2006 05:57 AM
pnoyster2k1cvic
Apr 19, 2004 06:59 PM
HitlistCivic01
Jun 13, 2002 07:57 AM
