2001 honda civic cluster problem - registering 30mph over.
I am haveing a problems with my 01 civic ex.
The cluster is registering 30mph over that what Im actually doing. Even at idle it sits at 30 and goes up accordingly.
thanks.
thanks.
Re: 2001 honda civic cluster problem - registering 30mph over.
needle position? if so will need open the dash/gauge and reposition
does it go down when the key is off?
thanks for the response.
when the key is off = hits 0
when key is engaged = hits 30
you see it falling down when you turn the car off.
Disconnect the battery cables and short them together for 10 minutes, then reconnect to battery and see if cluster still acts wrong.
If that doesn't change anything, I'd say it probably needs a cluster, or find a speedometer shop that repairs them.
There are a whole bunch of differences in clusters that aren't always readily visible so it's easy to run into issues if you don't do your research first.
Keep in mind, the odometer mileage is stored inside the cluster so if you get a used unit it will show whatever mileage was on the car it came out of. This could cause complications later on when you try to sell or trade if you don't have proper documentation of the change.
AND the speedo shop that might be able to repair a unit is also the place that can change the mileage in a used unit to match what's on the car now.
At work we use http://paspeedo.com/
HTH
You can try repositioning the needle, but it sounds like you probably have a bad stepper motor in the speedo.
alinaray
18
Aug 24, 2015 01:04 PM
guy
Jan 6, 2002 04:39 PM
oblivious9
Jan 1, 2002 07:12 PM
TopFuel
Exterior
Nov 13, 2001 07:05 PM
