my 2001 civic dx iddles
Old Dec 2, 2015
johnny18's Avatar
johnny18 is an unknown quantity at this point
My civics speedometer has a iddle when I start the car. I checked all fuses from the engine hood all are good, a mechanic tried to scan for codes but when he plugs in the scanner doesnt read or turn on the scanner at all? He told me it would be the main relay or computer, I need help, should I start woth the relay?
Old Dec 2, 2015
mac25's Avatar
Dr Krieger of Modification
Re: my 2001 civic dx iddles
...what?
I don't think you know the definition of "idle".
Idle is having the vehicle running while it is not in motion. At this point the engine rpm, or, rotations per minute, will be rotating at 1100rpm while cold, or 750rpm hot.
So every engine should idle.
Are you referring to a "lope at idle"? Where the rpm at idle shift up and down, without any driver input to the accelerator?
Old Dec 2, 2015
johnny18's Avatar
Originally Posted by mac25
...what?
You are correct I opoligize for the confusion, ok when I turn the car on all gages go up and down for about 3 sec then they go back to normal, they told me its an electrical problem
Old Dec 2, 2015
Do you mean the gauge needles shake or twitch several times when you turn the key on?
CLUE #1
Fuse is blown.
Fuse #9 in the engine compartment box, 10 amp.
Labeled BACK UP
HTH
jessica19699
Jul 29, 2015 05:51 AM
1khilari
Jul 9, 2015 08:12 PM
AZ2K1Civic
Jan 5, 2002 08:38 PM
Jr
Dec 1, 2001 09:20 PM
