8th Gen 2006 - 2011.
Check engine light
Old Oct 6, 2015
Enriquepd's Avatar
Enriquepd is an unknown quantity at this point
Check engine light
I have a civic 07 lx and the check engine line came up. The code they gave me p0848 for 3rd clutch transmission fluid switch. Where is it located and do i access it from the bottom or top of the car? Also is it an immediate concern? Thanks. First time forum user.
Old Oct 6, 2015
Re: Check engine light
Silver bullet:
Originally Posted by ezone
It's down low on the front, below the ATF cooler. Toward the far drivers side.
Single wire, black with red tracer.
Top view (if battery and everything were out of the way)
Here's a good one, looking up from under the front, splash shields removed
HTH
Old Oct 7, 2015
Enriquepd's Avatar
Silver bullet:
HTH
Thanks for the reoly. Does it need to be replaced immediately and what does that switch do?
Old Oct 7, 2015
The switch tells the computer that the trans did, in fact, receive fluid pressure to that gear and the shift should have occurred at that time.
The switches can fail completely but I usually see them as making intermittent contact faults. Either failure is a bad switch.
If the switch is bad, it needs replaced.
But if the wiring has been eaten by a rodent, it needs repaired.
I see a lot of chewed wiring in my area in addition to the switch failures.
hernandexz
Oct 28, 2021 10:52 PM
mistermenphis22
Apr 3, 2016 08:06 AM
markp94
Apr 30, 2015 09:19 PM
bahena08
Apr 11, 2015 05:09 PM
meels808
Nov 20, 2001 09:37 AM
