power steering pump too high...
Old Aug 26, 2015
7thgensurvivor's Avatar
7thgensurvivor is an unknown quantity at this point
Just installed new drive belts for alternator and power steering pump.
I have adjusted the wingnut for the power steering pump so as to get a decent amount of tension on the PS belt. To do so, I had to use every bit of the wingnut and bracket. The belt is not super tight, still gives a bit to medium pressure. The place where the mounting bolt sits on the mounting bracket is much higher than before, half inch to an inch, and is all the way at the top of the mounting bracket.
I purchased a MasterPro Serpentine belt K040398 from O'Reilly auto, also found here at
amazon amazon
. Supposed to fit 2002 honda civic ex 1.7L.
Wondering if others have their PS pump this high.
Here are a couple pics for reference:
Name:	ps pump too high.jpg
ID:	88022   Click image for larger version
Old Aug 26, 2015
Re: power steering pump too high...
If you ran out of adjustment travel, then your belt is too long.
The good thing is the PS belt does not have to be super tight like the alt/AC belt, it's only gotta be tight enough to not squall when you steer all the way to one side.
Old Aug 27, 2015
Figure it out. Been so long since I took things apart, I had a separate baggie with the second bolt that connects to the bottom portion of the power steering pump, the swing arc part. Once that was installed, things snugged up right where they used to be. Didn't have the wrong belt, just hadn't found a place for every part yet.
Old Aug 27, 2015
Well you leaving out important bolts wouldn't have been a first guess LOL
Old Aug 28, 2015
mikey1's Avatar
you are starting to make ME nervous about this job
are you sure you installed all of the cam bolts and head nuts?
sorry bad joke, but couldnt resist
Old Aug 28, 2015
How many different threads were started for this one job? I need to consolidate all of them into one.
Old Aug 28, 2015
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Nah, its all good. If you feel in the mood for consolidation there are 21k posts about overheating... 99% are the same symptoms of blown head gaskets.
Old Aug 28, 2015
That estimate might be kinda conservative.....
moorebl
Aug 29, 2015 08:39 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Mercilus
Jun 7, 2015 10:00 PM
vvr210
May 31, 2015 08:02 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
