Adjust Throttle Cable??
sup guys i too have a ? about the throttle cable....where exactly is the throttle cable and what do you exactly do to adjust it...i have basically everything on my car myself and i want to do this as well i just need to find out exactly what to do...can one of you that has done the throttle cable adjustment specify a little more than the DIY or is that exactly how ur supposed to do it??? like the DIY says??? help me out thanks
Look right next to the throttle body- you'll see the metal lever that pushes the throttle up when the line is pulled. Just get an adjustable wrench and tighten it so the lever is flush with the throttle. Do do it too much or you'll idle high.
I'm bigger than you.
Don't waste your time adjusting it, it won't make a difference....maybe in your mind it will, but it doesn't make a real difference. Now if you REALLY want increased performance, slap on some stickers baby!!!
<< Don't waste your time adjusting it, it won't make a difference....maybe in your mind it will, but it doesn't make a real difference. Now if you REALLY want increased performance, slap on some stickers baby!!! >>
that's right
7thgencivic.com sticker give a dyno proven 5 Hp increase
velozp
Dec 13, 2015 11:28 AM
IronFist
Sep 25, 2015 07:13 PM
Bricoleur
Sep 9, 2015 12:30 PM
