PLEASE help., cluster & small light
Old May 17, 2015
Ma213802's Avatar
Ma213802 is an unknown quantity at this point
I blew something.. Prob a wire touching.. Small light fuse kept blowing at touch of new fuse. Rewired my after market stereo. Small light fuse is now fine. However, my gauge cluster and small lights (gear shifter and such) plus the door chime, are not working. Something is blown, I just don't mnow what. Also on the cluster "srs" and "brake" light stay on. I have checked all fuses. Thank you!! I appriciate your time
Old May 17, 2015
GolNat's Avatar
Prelude Owner
Re: PLEASE help., cluster & small light
What were you doing? Installing a new radio or did this problem just start?
Year, and trim?
Old May 17, 2015
Ma213802's Avatar
At the moment I was putting LED bulb in my cluster. The stereo had been in the car for about a week at the time.
Year, and trim?
Old May 17, 2015
Ma213802's Avatar
2002 civic ex
Old May 17, 2015
Unplug everything related to the radio, then retry installing the fuse.
Make sure you did not connect anything to any wire marked 'illumination'.
This new LED you were installing in the cluster, did you get the polarity wrong?
Did you smell smoke? Smoke came out of the dash?
Burn a trace off of the cluster circuit board?
Old May 17, 2015
Ma213802's Avatar
No burn or smoke smell., don't remember hearing anything either. Not sure as far as trace.... Do small lights (gear shifter) run power through the cluster?
Old May 17, 2015
All of the dimmable dash lights do. The dimmer circuitry is in the cluster, a little wiring mistake can wipe it right out.
Old May 18, 2015
Ma213802's Avatar
So what should my next step be?
Old May 18, 2015
The first 3 lines of post #5 would be a place to begin
Check the 'meter' fuse too.
trellex
May 24, 2015 04:39 PM
jimmyfloyd
May 20, 2015 07:06 PM
steveneddy
May 19, 2015 02:39 PM
mievil
Apr 28, 2015 11:02 PM
bahena08
Apr 11, 2015 05:09 PM
