2005 SI VTEC Starter Replacement
Old Mar 19, 2015
mkrouse's Avatar
mkrouse is an unknown quantity at this point
I am the original owner of a 2005 Civic SI and would like to replace the starter.
Where is it located and how do you access it for replacement?
I bought a Helm manual but it doesn't have step by step instructions. My car starts fine 9 out of 10 times but occasionally it sounds like a grinding noise for about a second after starting. A mechanical noise, not an electrical buzz.
Marc
Arizona USA
Old Mar 19, 2015
mikey1's Avatar
Re: 2005 SI VTEC Starter Replacement
how do you know the starter is the problem?
Old Mar 19, 2015
mkrouse's Avatar
Good question. I don't know. The Helm trouble shooting is not much help. I might consider swapping out the starter cut relay under the dash.
The Helm manual seems to locate the starter in front of the engine, behind the the front cowl/bumper. I'd hate to remove the entire front bumper assembly. Not sure I have the patience. The dealer lists a new starter at $700 plus diagnostics and replacement labor. Sounds like a heavy bill.
I have a returnable Auto Zone remanufactured starter for the SI. Any suggestions would be appreciated.
Old Mar 19, 2015
mikey1's Avatar
your description of the problem is not very detailed,
i don't really have any suggestions off hand, all im saying is don't just go throwing random parts at it hoping it will solve the problem, its a waste of time and money
Old Mar 19, 2015
mkrouse's Avatar
your description of the problem is not very detailed.
Well, I don't know anything more than a grinding/whirring noise after starting that lasts less than a second. Occasional. I suspect the starter.
My money I guess, just looking for someone that can explain what has to be removed for access to the starter.
Old Mar 19, 2015
USA SI.
K engine.
That's handy information right there.
Starter is buried in the area under the intake manifold.
PITA IMO.
Disconnect battery
Disconnect knock sensor
Disconnect wiring brackets as necessary
Remove manifold bracket as necessary
Disconnect cables
Remove bolts and remove starter.
Simple, huh?
LOL
thana
Jun 15, 2020 07:05 PM
oqjoi
May 9, 2015 10:31 PM
SSMatey
Apr 13, 2015 06:09 PM
thesushiboy
Apr 12, 2015 02:54 AM
gabrown2
Apr 11, 2015 08:22 PM
