parts replacement for alignment
I asked honda to give me a list of recommendations of parts to replace in order to get my alignment done without it going back to what it is now (hope that makes sense). I know I need to replace my lower ball joints. They told me I need to replace the front lower bushings (I'm assuming those are the ones in the lower control arms?) And they said I need to replace the front sway bar end links. Do I really need to replace the end links? I didn't think that was an alignment critical item? Do I need to replace my rear end links as well then? (They didn't put those on the list). Thanks.
Re: parts replacement for alignment
Sway bar links are not part of alignment, but they can be annoyingly noisy when bad.
Is it difficult to replace lower control arm bushings? Do I need special tools? And I didn't think the sway bar end links served any alignment purpose so thanks for confirming
alternatively, you can buy an entire control arm with the bushings already installed
LOL!
Hmm... I might be able to do this, if I had a few pictures of someone actually using a press to get the bushings out? I have a hydraulic press at work I could use. Do I just push on the inner metal part with a socket or extension or something? Do I need to add some grease to the hole in the LCA before pressing in the new bushings?
Someone who uses a press regularly should be able to show you how, so ask around.
Correct orientation and alignment of the bushing is critical if using an original style part. Study the original and mark the new so it can go in exactly like the old one was.
HTH
oneheadlight
Apr 29, 2015 11:30 PM
bo_red
Apr 23, 2015 10:09 PM
GH04si
Apr 15, 2015 08:13 PM
thesushiboy
Apr 12, 2015 02:54 AM
