RPMs drop in neutral causing shaking vehicle?
Old Dec 11, 2014
dipmo13's Avatar
dipmo13 is an unknown quantity at this point
(2001 Honda Civic EX-Manual Transmission)
I always put my car in neutral whenever I am idling. However, recently I've noticed my RPMs drop very low (barely above zero) and the vehicle starts to shaking, and feels like it's about to kill. This only lasts for a few seconds and the RPM returns to normal (between 500 and 1000 rpm) and it steadies. Anyone know why it'd be doing this? I've been told replacing the O2 sensor and/or cleaning the IAC Valve might solve the problem. But would either of those cause the RPMs to drop like that? (Sorry I'm pretty new to this stuff)
Old Dec 11, 2014
Re: RPMs drop in neutral causing shaking vehicle?
Check engine light on?
Idle learn procedure?
Old Dec 11, 2014
dipmo13's Avatar
I've tried the idle learn procedure. It helps the general shakiness a little bit. But the RPMs still dip really low causing it to shake. The check engine light has not come on and no codes are brought up.
Old Dec 11, 2014
You said you cleaned the IAC....is it actually working?
Have you cleaned the throttle body?
Did you disconnect the battery or pull the fuse to wipe out idle memory prior to doing the idle learn?
Has it jumped time by a tooth?
Any other possible clues, does it run wrong at any other point or condition?
Just tossin out a few ideas.
Old Dec 13, 2014
dipmo13's Avatar
Looks like it was a faulty Throttle Position Sensor. Replaced the sensor, cleaned the IAC Valve and reset the idle memory. Seems to be fine now. Thanks for the help!
Cajunkev1
Apr 3, 2017 04:32 PM
The Big Dutch
Jun 9, 2015 07:49 PM
Wild Cranker
May 19, 2015 06:10 PM
crowtoo
May 11, 2015 06:50 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
