headlight bulb recommendations
Old Feb 28, 2014
hunnyjb's Avatar
hunnyjb is an unknown quantity at this point
sorry for the simple question but what bulb do you use? what do you think is best? the bulbs i bought was out of emergency and its not as bright/clear as i hoped it would be
Old Feb 28, 2014
got2run5's Avatar
got2run5 will become famous soon enoughgot2run5 will become famous soon enough
Re: headlight bulb recommendations
Sylvania Silverstar ultra or somethin like that is supposed to be the best. When I tried those and the lighting was still bad -------> Retrofit!
Old Feb 28, 2014
Poopies's Avatar
Super Moderator
Yeah, I used to use the Silverstars and then once I retrofitted, I wished I had done it long ago! Check the link in my sig for my results, or look around online. http://www.theretrofitsource.com/com...-3-kit-h1.html is a really good bet for a full kit.
Old Mar 1, 2014
mikey1's Avatar
if its the same wattage, then it should be the same,
your problem is most likely haze buildup on your lens, not the bulb
Old Mar 1, 2014
Poopies's Avatar
Super Moderator
+1 to that. They sell restoration kits for under $20 at any auto shop. They include sanding pads and sealant. A lot of people swear by Meguiars.
Old Mar 1, 2014
got2run5's Avatar
I tried cleaning my lenses but it didn't really help. In my opinion, the lights this car comes with are total crap.
Old Mar 1, 2014
Poopies's Avatar
Super Moderator
Care to take a picture of the lenses and of the output and show us?
Old Mar 1, 2014
bravo79's Avatar
bravo79 is an unknown quantity at this point
Amazon Amazon
Old Mar 2, 2014
CraigW's Avatar
After having driven in the pre halogen days from years ago.... I find Hondas setup quite nice.
You could always run to autozone and waste your money on some nice law enforcement blue hue headlights everyone is rocking these days.
Old Mar 2, 2014
BlueEM2's Avatar
Whachya lookin at?
Silverstar Ultras are nice.. Sure. Slightly brighter than OEM and they last about 1/20th of the time. Don't expect to get much more than 6 months to a year out of a set and they are ridiculously expensive. Go OEM and clear your lenses. At least you won't blind others.
Old Mar 2, 2014
mikey1's Avatar
agreed, and good point,
i find it so annoying when people have headlights too bright....isn't that what high beams are for?
Old Mar 2, 2014
BRBRT03's Avatar
BRBRT03 is an unknown quantity at this point
Just my $0.02 here, but IMO it is worth the investment into a set of retrofitted headlights if you plan to keep the car a while. Nothing will give you results like a projector/HID combo. I had the ones in my Stratus Coupe retrofitted and the difference was increadible. Considering doing the same to my Civic after a complete suspension overhaul but I think they have a pretty good setup for OE(my '96 DX does at least). Don't be the guy with HIDs in factory reflectors, just alot of wasted light.
Next best thing would be the Mequiars kit with the yellow buffing wheel for the drill. Compounds and Sealants last for a number of uses and if you need more paper just buy a 3M variety pack of 1000/2000/3000 grits and you will be set. I've done my two cars at least 3 times a year for the past couple years and still have tons of stuff left.
Silverstars are good, but they do burn out quicker than regular bulbs. I swear by them, put them in all my cars pre-retrofit.
SidCivic
44
Oct 12, 2017 03:39 PM
j-chest
Aug 11, 2015 02:26 PM
j-chest
Jul 31, 2015 01:18 PM
S1N7H3T1C
Jul 21, 2015 05:20 AM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
