So..61,000 miles and quit
Old Dec 22, 2012
1HGEM...'s Avatar
1HGEM... is an unknown quantity at this point
Hello...I have a 2002 Civic coupe with an automatic trans,just over 61k miles.Last week it started to make a whining/squealing sound, I thought it was the alternator going bad---wrong! My son had it out and said it was shifting bad, I checked the fluid, it was a little low but in the safe zone. I went for a drive and when it shifted from 2nd to 3rd it slipped a lot.Topped off the fluid and the whining got not as loud. -Next day took a while to engage when coming out of park,forward or reverse and slipped through the gears--Today no motion in any gear. Before I bought it it was involved in a front end crash and the front motor mount is no longer bolted to the motor it is welded. Is that piece between the motor and trans like a bellhousing or is it the torque converter case? The end question here - when the trans gets rebuilt will that need to be replaced? Here is a pic before it was welded looking down from the drivers side,I don't have any of it welded. Thanks!
Old Dec 22, 2012
Matt_75's Avatar
7th Gen Civic DIY Enthusiast!
Re: So..61,000 miles and quit
Umm yeah. I'd probably be using some coin to buy a reman trans. I personally would never trust a weld on something like that.
That's broke next to where the block and trans housing meet.
Old Dec 23, 2012
1HGEM...'s Avatar
I have been driving it for 6 months with it welded.I found a trans from a 2000 Civic on craigslist will that bolt up to a 2002?
Old Dec 23, 2012
I thought those pics looked familiar.
Back in April I said this:
Originally Posted by ezone
and there may be some risk.
If it works, it will save you a tall stack of loot.
But if it doesn't work, you needed a trans to fix it anyway.
It really sucks donkey ***** to find out your cheapazz ideas didn't work and now you have to do it all over again.
PLUS you now own a wrong or junk trans.
With that said.....
Won't work.
You are limited to 01-05 Civic.
You might be further limited to DX/LX, but I can't tell you that for sure.
Verify that with a wrecking yard, have them look it up in a Hollander Interchange guide.
And look on
http://www.car-part.com
http://www.mypartshop.com/
(I noticed a LOT that were listed have case damage.)
If you want a quality reman with some kind of warranty and not a junkyard unit, try a dealer sourced remanufactured transmission.....
or these guys: http://www.hnatrans.com/
Old Dec 23, 2012
1HGEM...'s Avatar
My "cheapazz" idea is working, the weld didn't fail...the trans did=different issue.The part numbers are the same for that case on a 2002 and 2000. Doesn't matter anyway..that one was sold. With the history of these transmissions I wouldn't throw one from a junkyard in with out having it freshened at least a little bit. I'll call around locally tomorrow.
Old Dec 23, 2012
My "cheapazz" idea
I meant Craigslist shopping, not the weld job.
I don't have access to an interchange guide myself. I just saw the part numbers for a complete trans were different between 00 and 02.
DX/LX are different from EX on the 02, but i still can't tell exactly what.
If gear ratios are different, it will not work. The PCM will code for gear ratio errors.
Old Dec 25, 2012
04 Honda Civic's Avatar
A proper tig weld will work.
You need to find someone who does it for a living.
Old Dec 26, 2012
DX/LX had a different gear ratio than an EX. EX is shorter so it will "feel" sportier
Old Jan 3, 2013
1HGEM...'s Avatar
Its rollin again...turns out,as expected the welding was ok, but the case was cracked on the inside and some internal parts had failed/ broken. Needed to get a new case....OUCH!! But it's rebuilt and shifting like a new car-as it should with all that $$ put out.
thana
Jun 15, 2020 07:05 PM
Cajunkev1
Apr 3, 2017 04:32 PM
Bradel26
May 30, 2015 10:24 AM
crowtoo
May 11, 2015 06:50 PM
bsmiley
Apr 27, 2015 01:27 PM
