Night Lights Issue
Old Jan 3, 2013
Bigman40's Avatar
Bigman40 is an unknown quantity at this point
Night Lights Issue
So, I have a 2001 Honda Civic (Ex), and it's been acting up on me for almost a year now in terms of the night lights (tail, parking, dash, and license plate lights). At first, the issue was a blown fuse, but lately, I've been able to hear my relay, under the steering wheel, click in an erratic manner. Sometimes the night lights would work and sometimes, it would have trouble starting for X amount of time.
I thought it would've been the relay, but when I switched it for an identical relay, the lights still wouldn't work. All my fuses to those lights (small lights, etc.) are not blown and working properly. Could this be a wiring issue?
I would hope that I can fix it myself instead of needing to take it in to the dealer. I've took the car in twice over the year and out of those times, the lights worked after my car was put back together, and at the dealership, the lights worked just after they took it into the back to check it out. Really stumped on what could cause the issue. Thanks in advance.
Old Jan 3, 2013
CraigW's Avatar
Re: Night Lights Issue
When you hear the relay I assume the lights come and go with the sound ?
Old Jan 3, 2013
Bigman40's Avatar
Nope. Lights won't work at all until some random point. Once they're on though, that tend to stay on for a while (up to days/weeks without going out).
Old Jan 3, 2013
CraigW's Avatar
When quiet can you hear a single click when turning on the parking lights ? (you should)
Old Jan 3, 2013
Bigman40's Avatar
When the lights are working correctly, there's a single click from the relay. However, the relay can click multiple times without the lights starting.
Old Jan 4, 2013
CraigW's Avatar
https://www.civicforums.com/forums/a...0&d=1267189121
You likely have the voltage to the taillight relay coil on WHT/GRN, and are getting the coils grounding via headlight switch. You could have a bad connection from the WHT/GRN leading to the relays contacts. Or after the switched side of the contacts leading to RED/YEL(ext lights) and RED/BLK (dash lights)
Old Jan 4, 2013
Bigman40's Avatar
That schematic helped me out tons. Where did you find that, and is there other parts that cover the rest of the car?
I was able to pull out the fuse box, but couldn't get into it to check the contacts. I saw a stripped wire (red/blk), so I taped it up before placing the fuse box. My lights work right now, but I still don't have a way to know whether it's a short or it's the contacts. So, I'll let the test of time answer that for me.
Also, I found out that I've had some wires cut prior to me owning the car. One wire going to a 555U timer, and another to my security feature. Are there any schematics that can show me the security and any others that contain a 555 timer?
Thanks in advance.
werdnahall
May 17, 2015 11:37 AM
jc33312
May 12, 2015 03:17 PM
tylerginevan
Apr 27, 2015 12:29 PM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
bo_red
Apr 21, 2015 12:55 PM
