How to prevent 97 Civic from starting
Old Dec 5, 2012
tlee808's Avatar
tlee808 is an unknown quantity at this point
Question How to prevent 97 Civic from starting
My 97 Civic was recently stolen. It has been recovered but the key area was broken and now anyone can start it by just turning the plastic switch which was part of the key wiring. I'd like to find a simple way to disable my car from starting while it is parked in my covered parking space for days at a time. Is there a simple way to to disconnect some thing to prevent my car from starting? Or is there some kind of switch I could put in to prevent starting the engine? I tried looking ta the fuses but they seem to be screwed down. I do not want to get an alarm, just a simple and easy way to prevent starting. The car is driven about 2 or 3 times a week.
Thanks for your suggestions.
Old Jan 24, 2013
marek91's Avatar
marek91 is an unknown quantity at this point
Re: How to prevent 97 Civic from starting
pull the starter fuse ?
Old Jan 24, 2013
tlee808's Avatar
Thanks for your suggestion.
I did look at the fuses but I did not see a starter fuse.
Where is it?
Old Jan 24, 2013
Stock 99's Avatar
could try this...
ID:	84605   Click image for larger version
Old Jan 24, 2013
Stock 99's Avatar
... or if it's an auto you could do this
https://www.civicforums.com/forums/4...ml#post4556126
Old Jan 24, 2013
NAcaRice's Avatar
Low `n` Slow
NAcaRice is an unknown quantity at this point
Removing the fuse is the easiest unless the robber has a spare on him haha. But you could put a wheel lock (tire of steering wheel) which prevents it from moving anywhere. You could also try and removing the coil wire. OR disconnect the battery and store the battery where a robber cant see so that it wont start
MN-02-CivicEx
28
May 2, 2015 09:11 PM
SSMatey
Apr 13, 2015 06:09 PM
jaje
38
May 16, 2009 12:29 AM
2001LX
Nov 8, 2001 05:13 PM
artychris
Oct 24, 2001 10:14 AM
