Quick Suspension Question
Old Jul 29, 2012
lollygagger's Avatar
Person
lollygagger has a spectacular aura aboutlollygagger has a spectacular aura about
So I was installing the A-Spec suspension yesterday on my EP3 and got three of the four combos in. The left rear trailing arm bolt was seized terribly and I ended up round off the head. Is there a way I can remove this? I'm going down the route of "will need a new bolt" which is fine by me, but I just want the darn thing out. Thanks fellas
Old Jul 29, 2012
GolNat's Avatar
Prelude Owner
Re: Quick Suspension Question
You can Dremel a slot in the head of the bolt , then take an impact gun, and flat head and get it out. You could also hammer a slightly smaller socket onto the end of it and use an impact gun. You will loose a socket but the bolt will be out. If all else fails you can get an Easy-Out and drill it out.
Old Jul 29, 2012
Person
Tried the smaller socket trick to no avail. It's rounded and slightly pointed at the top so it basically twists itself loose when tried to torque it off. Anything smaller also will not make itself down towards the back of the head. I've read that drilling through the shock and just to the bolt to get PB Blaster will work. The problem is that the bushing sleeve isn't Zinc plated, but the bolt is.... the two become one
Old Jul 30, 2012
MindBomber's Avatar
Live for the Twisties
Use a reciprocating saw or an angle grinder to cut through the bolt and disconnect the shock from the trailing arm, the bolt seizes to the metal collar inside the bushing so unfortunately this is necessary. You could theoretically use a hack saw, but it would take a long long time due to the high strength of suspension bolts. Once most of the bolt is removed, you should be able to get a grip on the last piece of the bolt using vice grips.
Old Jul 30, 2012
ouchie...
MB said most of them, so good luck, bud.
Old Jul 31, 2012
sl33pyriceboi's Avatar
spray the **** out of it with PB plaster. let it soak for a few hrs. then use a vice grip and take that nut/bolt off.
Old Jul 31, 2012
MindBomber's Avatar
Another thing to note, torching it should be the last option explored. Heating up suspension components is considered a very poor practice if they won't be replaced. The act of torching it, then spraying penetrating lube, tempers the metal and to a possibly dangerous degree increases the ductility of the metal which could result in a shear under load.
Old Aug 5, 2012
Person
Yeah I was not gonna resort to heating as it was the strut closest to the gas tank. The ol' reciprocating saw worked like a charm. After about a half hour of cutting it came out and the new strut went right in. Along with a new bolt of course. My dad wants to see if he can get that slug out now that's trapped..
15EXCoupe
Jul 30, 2015 12:59 PM
Misfit2613
Jul 30, 2015 09:49 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
mokkush
Jul 14, 2015 04:05 PM
NoobyKid
Jul 13, 2015 07:53 AM
