Godspeed Camber Kit? Your Opinion
Civic Novice
Rep Power: 0 Godspeed Camber Kit? Your Opinion
I done some searching and really never came up with any good info. I was curious has anyone ever used the Godspeed camber kit before? If so, have you had good luck with them or are they junk?
If they are junk what camber kits do you recommend (reasonably priced)?
I'm needing to order some and looking for suggestions. Thanks in advance
1 Post
Rep Power: 156 Re: Godspeed Camber Kit? Your Opinion
I don't have personal experience with it, but my friend had Godspeed camber bolts on the front of his Celica. Within months, the threads were completely stripped under normal driving conditions. The metal was unbelievably soft and pliable after running the car.
I haven't heard much about the rear camber kits, but knowing what I know about the poor material used to make the front bolts, I would suspect the rears to be similar. They will probably be fine for a while, but make sure to check them out often. Coat them with rust-proof paint first too, to slow possible decay of the low grade metals.
Great reasonably priced options are: Megan Racing, Wicked Tuning, or mildly used Ingalls or SPC
Civic Novice
Rep Power: 0 Re: Godspeed Camber Kit? Your Opinion
1 Post
If you have a 7th, lots of guys recommend the Megan Racing rear camber kit. Very good quality for the price. Not so many have tried the newer Wicked Racing kit, but it appears to be very good too. Personally, I have Ingalls, but only because I got a very good deal on them from an RSX owner.
Civic Novice
Do you have a 7th gen? or an older Civic?
I like the Ingalls the best but a little more than I want to spend right now.
1 Post
By all means, go for the Megan Racing kit. People have had great luck with those. Save those poor tires
I would stay away from the Wicked Tuning chamber kit I bought the rear set for my car, it fits perfect and everything was fine, then about 8 months down the road the rear right side camber snapped on me while I was on the freeway.
making the car on undrivable. I was just happy it didn't end worst at least I was able to some what move the car to the side. anyways after that I am with ingalls now.
Rep Power: 232 Re: Godspeed Camber Kit? Your Opinion
yeah godspeed and megan are just glorified ebay products that are fine for things like exhaust and miniscule items but i wouldn't trust them for suspension components. the ingalls smart arms are probably the most durable arm you can find. i mean just look at the difference
http://www.corsportusa.com/store/cat...roducts_id=275 why would you take that chance just to save 80 bucks ???
Received 1,144 Likes
Rep Power: 485 Re: Godspeed Camber Kit? Your Opinion
I've had the same SPC rear camber kit installed on my car since 2004. Hasn't failed me yet
Dave Brabant
20
10-06-2015 12:44 AM
Hutch1051
09-29-2015 09:20 AM
