Cam Belt Change Questions
Old Mar 23, 2012
jonnyl888's Avatar
jonnyl888 is an unknown quantity at this point
I'm about the change the cam belt and water pump in my civic ep2 (European) with 89k miles on the clock (d16v1 engine). But I have a few questions:
- Why do I need to set piston 1 to TDC? If I'm really careful and do not move anything when replacing the belt it should be exactly the same right?
- Instead of the TDC method, I've seen people put their own mark on the belt and the cam and crank shaft sprockets then transferring the belt marks to the new belt and aligning the new belt to the marks.
- Im my Haynes manual it says remove the starter and stick a screwdriver in one of the holes to jam the flywheel. Does this method work?
Thanks, any other tips and warnings would be appreciated.
Old Mar 23, 2012
Re: Cam Belt Change Questions
Do you have some huge problem with following simple instructions?
What if the belt is "out of time" already? You are going to reinstall a brand new belt the same wrong way the old one was.
How would any smart person know if it was out of time?
There are timing marks already scribed on the gears from the factory. They will line up with other points or marks on the block, oil pump, or head when the crank is at #1TDC.
If you don't have the crank and cam at TDC when you pull the belt off, valve spring pressure can cause the cam to turn to a new position, and you really don't need this to happen.
These engines bend valves when the cam/crank are out of time too far.
Aaaaaand what part is this related to?What step is this on? What part is being disassembled when the "book" says to do this?
Old Mar 23, 2012
jonnyl888's Avatar
I've never turned the crank manually before so it all seems a bit scary.
The book says put a screwdriver into one of the holes so it locks the flywheel against the screw driver and flywheel teeth, so the crankshaft doesn't move. Easy alternative to a flywheel lock.
Is it safe to freely rotate the crankshaft while the belt is still on? Does it have to be in a specific direction?
Old Mar 23, 2012
read the stickies and DIY threads on the site.
not gonna say everything again, it's in there for who searches.
Old Mar 23, 2012
Why does your book say to do this?
I can only think of one reason (maybe two), and I want to know what your book says.
Old Mar 24, 2012
04 Honda Civic's Avatar
So the crankshaft dont spin when your removing the bolt is my guess.
They actually make a tool for this, look into it. Probably a better way and safter way.
If you have a good impact and a good compressor, maybe a oxy/set torch thats your best bet.
"Is it safe to freely rotate the crankshaft while the belt is still on? Does it have to be in a specific direction?"
How else do you expect to get the piston at TDC and all the marks to line up before you remove the belt?
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
slynger
18
May 8, 2015 06:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
thesushiboy
Apr 12, 2015 07:40 PM
viper775
Dec 9, 2001 10:52 PM
