01 DX brake light problem
Old Feb 27, 2012
andyczs's Avatar
andyczs is an unknown quantity at this point
When I switch on the lights, the brake light is not on,
but it works when I depress the brake.
Should both the tail light and the brake light stay on when you switch on the lights~? and when you depress the brake, the brake light grows brighter~ right?
Thank you.
Old Feb 27, 2012
CraigW's Avatar
Re: 01 DX brake light problem
Are your licence lights operating when lights on ??
Front marker lights on corners when lights are on ??
The brake and tail bulb has 2 separate filaments.
Old Feb 28, 2012
andyczs's Avatar
When I switch the lights on, all front headlights, front marker lights, front and rear signal lights, licence lights and the tail light(the one on the trunk) are all functioning properly, except the brake light.
reverse lights work too~
Old Feb 28, 2012
CraigW's Avatar
If just one light is out...? you likely need a bulb.
Old Feb 28, 2012
andyczs's Avatar
I have replaced the bulbs already~ still it's not working when I swtuch the lights on~ though it lights up when I depress the brake
Xuhme
21
Aug 7, 2023 03:40 PM
Poopies
Apr 20, 2017 11:36 PM
trellex
May 24, 2015 04:39 PM
jakeconnor
May 5, 2015 07:30 AM
McD
Apr 29, 2015 03:50 PM
