01 DX brake light problem
Old 02-27-2012
andyczs's Avatar
andyczs is an unknown quantity at this point
When I switch on the lights, the brake light is not on,
but it works when I depress the brake.
Should both the tail light and the brake light stay on when you switch on the lights~? and when you depress the brake, the brake light grows brighter~ right?
Thank you.
Old 02-27-2012
CraigW's Avatar
Re: 01 DX brake light problem
Are your licence lights operating when lights on ??
Front marker lights on corners when lights are on ??
The brake and tail bulb has 2 separate filaments.
Old 02-28-2012
andyczs's Avatar
When I switch the lights on, all front headlights, front marker lights, front and rear signal lights, licence lights and the tail light(the one on the trunk) are all functioning properly, except the brake light.
reverse lights work too~
Old 02-28-2012
CraigW's Avatar
If just one light is out...? you likely need a bulb.
Old 02-28-2012
andyczs's Avatar
I have replaced the bulbs already~ still it's not working when I swtuch the lights on~ though it lights up when I depress the brake
Xuhme
21
08-07-2023 03:40 PM
Poopies
04-20-2017 11:36 PM
trellex
05-24-2015 04:39 PM
jakeconnor
05-05-2015 07:30 AM
McD
04-29-2015 03:50 PM
Quick Reply: 01 DX brake light problem
