Oil Pan removal
Old Feb 27, 2012
nieuport17's Avatar
nieuport17 is an unknown quantity at this point
Oil Pan removal
I got a oil leak on the oil pan, need to replace the gasket.
While under the car, I noticed that the transmission is in the way....
Do I have to remove the transmission to get to the Oil Pan? That's kinda silly...
Thank you : )
Old Feb 27, 2012
Re: Oil Pan removal
They wouldn't build it like that.
Old Feb 27, 2012
nieuport17's Avatar
Re: Oil Pan removal
lol, guess I'll have to take a picture and re post : )
Old Feb 27, 2012
Re: Oil Pan removal
Seriously. They don't build them like that. The oil pan will come straight down after you get all the junk out of the way.
You don't touch the trans. There might be a cast aluminum piece that needs removed, but you don't remove the trans.
Try a service manual.
Old Feb 28, 2012
nieuport17's Avatar
Re: Oil Pan removal
Thank you ezone, you are right on the nose on the big aluminum piece that is in the way. I always thought that's part of the transmission.
And I need a little help on finding info on how to remove the "big aluminum" piece that is in the way.
I have the service manual and the haynes manual... and I can't find the info from both.
Haynes don't even mention the aluminum piece. And the service manual... well, if it is there, I can't find it...
Old Feb 28, 2012
Re: Oil Pan removal
Sorry man, I can't hold your hand through this. You need to get a flashlight and crawl under it and find the bolts that hold it on. There are at least 4, maybe more.
Vaguexo
Jun 13, 2015 04:11 AM
jmdcivic
May 20, 2015 09:52 PM
BootyDo
May 7, 2015 04:46 PM
leon1
Apr 28, 2015 07:32 PM
Grey
16
Jan 27, 2002 11:34 PM
